I was wondering how easy it would be to add being able to command two actions as the result of one heating or cooling command. What I am wanting to accomplish is use the valves you sell to control heating (as I mentioned in my other post) which you said should be easy to do, but the way i want to set it up is that if heating is needed valve ONE is opened and valve TWO is closed. i am not currently seeing where that would be possible since heating and cooling are controlled as single individual actions. Easiest was i could see it implemented is some sort of way to where if heat needed turn on (open) this valve and have a AND command for some other action.
If anyone has any advice or insight that would be great
