I am setting up my new Spark 4 with a fermentation fridge, and I am running into some difficulties. When using the Wizard, I am not able to progress beyond the selection of temperature sensors. I get a “no entry” icon when I try to click next. I have then gone to setting it up manually, but I am not able to access the channels on my DS2413. When try to open the “advanced” dialogue on the Digital Actuator, I get a blank screen. And when I look at the Digital Actuators they, quite rightly, state that no channels have been selected.
I have reloaded the UI a few times since. Wrt the Mock Pins, then I fail to create the block. I get the response: Error: Request Failed with status code 400.
Regardless of the Mock Pins block creation, I still cannot proceed beyond the fourth screen in the Wizard, the “Assign Hardware Blocks” step.
I have looked at the Digital Actuators setup on my Spark 3 wit functioning temperature control, and here I am also seeing a blank window when I go to the advanced settings.
It looks like you’re still running an older version of the software. To fix this, run brewblox-ctl update.
Be aware that the update also includes a change of databases, that requires running a migration command.
The output from update will tell you what commands to run.
Quick update. I have done a couple of refreshes of the UI, and now there appears to be some changes. The Wizard still doesn’t work. I will try the manual build and get back to you.
Sorry for the late reply, reality took over. The build date is 2021-10-14T11:10:00.467Z.
I have built the temperature control for the fermentation chamber manually and everything is working as it should, apart from the Wizard but that is not so critical now for me.
