Is there a way to disable the start up beep on the Spark V3? It drives my dog crazy. And could this beep also be used as an alarm?
Haha, I’m afraid the startup beep cannot be disabled.
But why is this a problem? It shouldn’t sound often. Are you restarting often?
The plan is indeed to use that as an alarm too, but we still have to code that part. We’re focusing on multi-process control first.
Started a few times during set up due to quite a few bad micro USB cables between the Spark V3 and RPi3, so no communication but it would power up fine. I need to set up WiFi. Thanks and keep the focus on the multi-process, my dog and many others will appreciate that much more. Cheers
