Firmware release date: 2019/08/20
To make it easier to edit the configuration, we added a web-based editor for the docker-compose.yml file.
You can start it by running brewblox-ctl editor, and visiting the Pi IP at port 8300.
To avoid redirection issues we’ve moved the UI to the /ui/ subdirectory. If you navigate to https://PI_ADDRESS you’ll be automatically redirected. This fixes multiple issues with accessing the datastore on startup.
Changes
- Added the
editorcommand to brewblox-ctl. - Moved UI address root from
/to/ui. - Pinned Docker image versions for external services (datastore, influx, and traefik).
- Fixed erronous period stretching in the firmware when PWM duty alternates between under and over 50%.
- Added
?safeURL parameter to disable loading remote plugins.- This allows removing plugins that prevent the UI from rendering.
- Improved the Step view diff tooltip.
- Actuator state is now printed as
Active,Inactive,Unknowninstead of a number. - Changed values are now rendered with old values in red, and new values in green.
- Unchanged values are now rendered as a single value, instead of
old => new.
- Fixed a bug in Builder where a new part would be placed at an incorrect location.
- Disabled the Editor button in IE/Edge browsers due to a breaking bug.
- Improved help texts in the Builder settings screen.
- Third-party plugins can now register Builder parts.
- We’ll be working to allow third-party plugins to acces helper functions.
- Fixed a bug where the UI would return a 200 status code for
/datastoreand/historyendpoints if the datastore/history service is not (yet) online. - Fixed a bug where changing duration in a Block graph would not re-render the graph.
Relevant links:
