After running this update, my Pi is now stuck with traefik “restarting”, everything else is “Up” and it’s had a reboot. Could I ask for any pointers, please?
(Is this the right place to post this?)
I managed to find some logs… The hilight is below:
traefik error: failed to decode configuration from flags: field not found, node: c
pi@BrewBlox:~/brewblox $ docker-compose logs -f
Attaching to brewblox_spark_1, brewblox_history_1, brewblox_eventbus_1, brewblox_traefik_1, brewblox_mdns_1, brewblox_influx_1, brewblox_datastore_1, brewblox_ui_1
spark_1 | 2019/09/18 15:50:11 INFO brewblox_service.service Creating [spark] application
spark_1 | 2019/09/18 15:50:11 INFO __main__ INI: firmware_version='4a67dd2a', firmware_date='2019-09-16 11:25:26 +0200', proto_version='54c9b94', proto_date='2019-09-12 15:47:51 +0200', system_version='1.2.1-rc.2'
spark_1 | 2019/09/18 15:50:11 INFO __main__ CONFIG: host='0.0.0.0', port='5000', output='None', name='spark', debug='False', eventbus_host='eventbus', eventbus_port='5672', simulation='False', device_host='None', device_port='8332', device_serial='None', device_id='None', discovery='all', list_devices='False', broadcast_exchange='brewcast', broadcast_interval='5', sync_exchange='syncast', mdns_host='172.17.0.1', mdns_port='5000', volatile='False', skip_version_check='False'
spark_1 | 2019/09/18 15:50:14 INFO brewblox_service.service Service info: 0.5.2-193-g2feef17 @ Mon Sep 16 09:44:00 UTC 2019
spark_1 | 2019/09/18 15:50:14 INFO brewblox_service.events Closing <EventListener for "eventbus">
spark_1 | 2019/09/18 15:50:14 INFO ..._devcon_spark.communication Starting device discovery, type=all
spark_1 | 2019/09/18 15:50:14 INFO ..._devcon_spark.communication Automatically detected ['/dev/ttyACM0', 'Photon - Photon Serial', 'USB VID:PID=2B04:C006 SER=1d003e001847353236343033 LOCATION=1-1.3:1.0']
spark_1 | 2019/09/18 15:50:14 INFO ..._devcon_spark.communication discovered usb /dev/ttyACM0
spark_1 | 2019/09/18 15:50:14 INFO ...ox_devcon_spark.broadcaster Starting Broadcaster
spark_1 | 2019/09/18 15:50:14 INFO ...ox_devcon_spark.api.sse_api Starting SSEPublisher
spark_1 | 2019/09/18 15:50:14 INFO ..._devcon_spark.communication Connected <SparkConduit for /dev/ttyACM0>
spark_1 | 2019/09/18 15:50:15 INFO ...blox_devcon_spark.commander HandshakeMessage(name='BREWBLOX', firmware_version='1710c022', proto_version='7a2a6a9', firmware_date='2019-08-20', proto_date='2019-07-15', system_version='1.2.1-rc.2', platform='photon', reset_reason_hex='46', reset_data_hex='00', reset_reason='UPDATE')
spark_1 | 2019/09/18 15:50:15 WARNING py.warnings /usr/local/lib/python3.7/site-packages/brewblox_devcon_spark/status.py:101: UserWarning: Handshake failed: firmware incompatible
spark_1 | warnings.warn('Handshake failed: firmware incompatible')
spark_1 |
spark_1 | 2019/09/18 15:50:15 ERROR brewblox_devcon_spark.seeder Incompatible firmware version detected
spark_1 | 2019/09/18 15:56:15 INFO brewblox_service.events Closing <EventListener for "eventbus">
history_1 | /usr/local/lib/python3.7/site-packages/aioinflux/compat.py:12: UserWarning: Pandas/Numpy is not available. Support for 'dataframe' mode is disabled.
eventbus_1 | 2019-09-18 15:51:03.046 [info] <0.8.0> Feature flags: list of feature flags found:
eventbus_1 | 2019-09-18 15:51:03.047 [info] <0.8.0> Feature flags: feature flag states written to disk: yes
eventbus_1 | 2019-09-18 15:51:03.157 [info] <0.223.0>
eventbus_1 | Starting RabbitMQ 3.7.17 on Erlang 22.0.7
eventbus_1 | Copyright (C) 2007-2019 Pivotal Software, Inc.
eventbus_1 | Licensed under the MPL. See https://www.rabbitmq.com/
eventbus_1 |
eventbus_1 | ## ##
history_1 | warnings.warn(no_pandas_warning)
spark_1 | 2019/09/18 15:56:15 INFO brewblox_service.events Closing <EventPublisher for "eventbus">
eventbus_1 | ## ## RabbitMQ 3.7.17. Copyright (C) 2007-2019 Pivotal Software, Inc.
eventbus_1 | ########## Licensed under the MPL. See https://www.rabbitmq.com/
spark_1 | ======== Running on http://0.0.0.0:5000 ========
history_1 | 2019/09/18 15:49:58 INFO brewblox_service.service Creating [history] application
eventbus_1 | ###### ##
history_1 | 2019/09/18 15:49:58 INFO brewblox_service.events Deferred event bus subscription: [<# @ brewcast>]
history_1 | 2019/09/18 15:50:00 INFO brewblox_service.service Service info: 0.9.0-34-gae61b31 @ Tue Sep 3 09:20:57 UTC 2019
eventbus_1 | ########## Logs: <stdout>
history_1 | 2019/09/18 15:50:00 INFO brewblox_service.events Closing <EventListener for "eventbus">
history_1 | 2019/09/18 15:50:00 INFO brewblox_service.events <EventListener for "eventbus"> now listening
eventbus_1 |
spark_1 | (Press CTRL+C to quit)
eventbus_1 | Starting broker...
eventbus_1 | 2019-09-18 15:51:03.164 [info] <0.223.0>
spark_1 | 2019/09/18 16:00:17 INFO brewblox_service.service Creating [spark] application
eventbus_1 | node : rabbit@8de728814566
eventbus_1 | home dir : /var/lib/rabbitmq
eventbus_1 | config file(s) : /etc/rabbitmq/rabbitmq.conf
eventbus_1 | cookie hash : Ce3ceML7yd7ACojmuWNziw==
eventbus_1 | log(s) : <stdout>
eventbus_1 | database dir : /var/lib/rabbitmq/mnesia/rabbit@8de728814566
eventbus_1 | 2019-09-18 15:51:03.252 [info] <0.223.0> Running boot step pre_boot defined by app rabbit
eventbus_1 | 2019-09-18 15:51:03.253 [info] <0.223.0> Running boot step rabbit_core_metrics defined by app rabbit
eventbus_1 | 2019-09-18 15:51:03.258 [info] <0.223.0> Running boot step rabbit_alarm defined by app rabbit
eventbus_1 | 2019-09-18 15:51:03.277 [warning] <0.229.0> You are using a 32-bit version of Erlang: you may run into memory address~nspace exhaustion or statistic counters overflow.~n
eventbus_1 | 2019-09-18 15:51:03.281 [info] <0.229.0> Memory high watermark set to 370 MiB (388425318 bytes) of 926 MiB (971063296 bytes) total
mdns_1 | 2019/09/18 15:49:41 INFO brewblox_service.service Creating [mdns] application
spark_1 | 2019/09/18 16:00:17 INFO __main__ INI: firmware_version='4a67dd2a', firmware_date='2019-09-16 11:25:26 +0200', proto_version='54c9b94', proto_date='2019-09-12 15:47:51 +0200', system_version='1.2.1-rc.2'
spark_1 | 2019/09/18 16:00:17 INFO __main__ CONFIG: host='0.0.0.0', port='5000', output='None', name='spark', debug='False', eventbus_host='eventbus', eventbus_port='5672', simulation='False', device_host='None', device_port='8332', device_serial='None', device_id='None', discovery='all', list_devices='False', broadcast_exchange='brewcast', broadcast_interval='5', sync_exchange='syncast', mdns_host='172.17.0.1', mdns_port='5000', volatile='False', skip_version_check='False'
traefik_1 | 2019/09/18 15:49:38 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 15:49:49 command traefik error: failed to decode configuration from flags: field not found, node: c
spark_1 | 2019/09/18 16:00:19 INFO brewblox_service.service Service info: 0.5.2-193-g2feef17 @ Mon Sep 16 09:44:00 UTC 2019
spark_1 | 2019/09/18 16:00:19 INFO brewblox_service.events Closing <EventListener for "eventbus">
datastore_1 | ****************************************************
mdns_1 | 2019/09/18 15:49:41 INFO brewblox_service.service Service info: 0.2.1-20-g61dc97f @ Tue Sep 3 09:21:26 UTC 2019
eventbus_1 | 2019-09-18 15:51:03.301 [info] <0.231.0> Enabling free disk space monitoring
history_1 | /usr/local/lib/python3.7/site-packages/brewblox_service/events.py:241: UserWarning: Connection error in <EventListener for "eventbus">: ConnectionRefusedError([Errno 111] Connect call failed ('172.20.0.6', 5672))
datastore_1 | WARNING: CouchDB is running in Admin Party mode.
datastore_1 | This will allow anyone with access to the
eventbus_1 | 2019-09-18 15:51:03.301 [info] <0.231.0> Disk free limit set to 50MB
history_1 | warnings.warn(f'Connection error in {self}: {strex(ex)}')
datastore_1 | CouchDB port to access your database. In
datastore_1 | Docker's default configuration, this is
spark_1 | 2019/09/18 16:00:19 INFO ..._devcon_spark.communication Starting device discovery, type=all
spark_1 | 2019/09/18 16:00:19 INFO ..._devcon_spark.communication Automatically detected ['/dev/ttyACM0', 'Photon - Photon Serial', 'USB VID:PID=2B04:C006 SER=1d003e001847353236343033 LOCATION=1-1.3:1.0']
eventbus_1 | 2019-09-18 15:51:03.317 [info] <0.223.0> Running boot step code_server_cache defined by app rabbit
datastore_1 | effectively any other container on the same
history_1 | 2019/09/18 15:51:02 INFO brewblox_history.influx Connected <InfluxWriter brewblox>
history_1 | 2019/09/18 15:51:05 WARNING aioamqp.protocol only PLAIN login_method is supported, falling back to AMQPLAIN
history_1 | 2019/09/18 15:51:06 INFO brewblox_service.events Connected <EventListener for "eventbus">
eventbus_1 | 2019-09-18 15:51:03.318 [info] <0.223.0> Running boot step file_handle_cache defined by app rabbit
eventbus_1 | 2019-09-18 15:51:03.320 [info] <0.234.0> Limiting to approx 1048476 file handles (943626 sockets)
eventbus_1 | 2019-09-18 15:51:03.321 [info] <0.235.0> FHC read buffering: OFF
eventbus_1 | 2019-09-18 15:51:03.321 [info] <0.235.0> FHC write buffering: ON
spark_1 | 2019/09/18 16:00:19 INFO ..._devcon_spark.communication discovered usb /dev/ttyACM0
datastore_1 | system.
history_1 | 2019/09/18 15:51:06 INFO brewblox_service.events Declaring event bus subscription <# @ brewcast> on <aioamqp.channel.Channel object at 0x73ba6990>
mdns_1 | ======== Running on http://0.0.0.0:5000 ========
eventbus_1 | 2019-09-18 15:51:03.325 [info] <0.223.0> Running boot step worker_pool defined by app rabbit
traefik_1 | 2019/09/18 15:49:58 command traefik error: failed to decode configuration from flags: field not found, node: c
spark_1 | 2019/09/18 16:00:19 INFO ...ox_devcon_spark.broadcaster Starting Broadcaster
datastore_1 | Use "-e COUCHDB_USER=admin -e COUCHDB_PASSWORD=password"
mdns_1 | (Press CTRL+C to quit)
traefik_1 | 2019/09/18 15:50:07 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 15:50:16 command traefik error: failed to decode configuration from flags: field not found, node: c
datastore_1 | to set it in "docker run".
spark_1 | 2019/09/18 16:00:19 INFO ...ox_devcon_spark.api.sse_api Starting SSEPublisher
traefik_1 | 2019/09/18 15:50:25 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 15:50:36 command traefik error: failed to decode configuration from flags: field not found, node: c
mdns_1 | 2019/09/18 16:00:01 INFO brewblox_service.service Creating [mdns] application
datastore_1 | [os_mon] cpu supervisor port (cpu_sup): Error writing to Erlang
datastore_1 | [os_mon] memory supervisor port (memsup): Erlang has closed
traefik_1 | 2019/09/18 15:50:51 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 15:51:11 command traefik error: failed to decode configuration from flags: field not found, node: c
spark_1 | 2019/09/18 16:00:19 INFO ..._devcon_spark.communication Connected <SparkConduit for /dev/ttyACM0>
traefik_1 | 2019/09/18 15:51:41 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 15:52:35 command traefik error: failed to decode configuration from flags: field not found, node: c
history_1 | 2019/09/18 15:56:15 INFO brewblox_service.events Cancelled <EventListener for "eventbus">
traefik_1 | 2019/09/18 15:53:38 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 15:54:41 command traefik error: failed to decode configuration from flags: field not found, node: c
spark_1 | 2019/09/18 16:00:20 INFO ...blox_devcon_spark.commander HandshakeMessage(name='BREWBLOX', firmware_version='1710c022', proto_version='7a2a6a9', firmware_date='2019-08-20', proto_date='2019-07-15', system_version='1.2.1-rc.2', platform='photon', reset_reason_hex='28', reset_data_hex='00', reset_reason='POWER_DOWN')
traefik_1 | 2019/09/18 15:55:46 command traefik error: failed to decode configuration from flags: field not found, node: c
eventbus_1 | 2019-09-18 15:51:03.326 [info] <0.224.0> Will use 4 processes for default worker pool
spark_1 | 2019/09/18 16:00:20 WARNING py.warnings /usr/local/lib/python3.7/site-packages/brewblox_devcon_spark/status.py:101: UserWarning: Handshake failed: firmware incompatible
history_1 | 2019/09/18 15:56:15 ERROR aioamqp.protocol error on dispatch
eventbus_1 | 2019-09-18 15:51:03.327 [info] <0.224.0> Starting worker pool 'worker_pool' with 4 processes in it
traefik_1 | 2019/09/18 16:00:04 command traefik error: failed to decode configuration from flags: field not found, node: c
mdns_1 | 2019/09/18 16:00:02 INFO brewblox_service.service Service info: 0.2.1-20-g61dc97f @ Tue Sep 3 09:21:26 UTC 2019
history_1 | Traceback (most recent call last):
eventbus_1 | 2019-09-18 15:51:03.330 [info] <0.223.0> Running boot step database defined by app rabbit
eventbus_1 | 2019-09-18 15:51:03.332 [info] <0.223.0> Node database directory at /var/lib/rabbitmq/mnesia/rabbit@8de728814566 is empty. Assuming we need to join an existing cluster or initialise from scratch...
history_1 | File "/usr/local/lib/python3.7/site-packages/aioamqp/protocol.py", line 315, in run
eventbus_1 | 2019-09-18 15:51:03.333 [info] <0.223.0> Configured peer discovery backend: rabbit_peer_discovery_classic_config
eventbus_1 | 2019-09-18 15:51:03.334 [info] <0.223.0> Will try to lock with peer discovery backend rabbit_peer_discovery_classic_config
spark_1 |
eventbus_1 | 2019-09-18 15:51:03.335 [info] <0.223.0> Peer discovery backend does not support locking, falling back to randomized delay
history_1 | await self.dispatch_frame()
history_1 | File "/usr/local/lib/python3.7/site-packages/aioamqp/protocol.py", line 263, in dispatch_frame
traefik_1 | 2019/09/18 16:00:11 command traefik error: failed to decode configuration from flags: field not found, node: c
history_1 | frame_channel, frame = await self.get_frame()
history_1 | File "/usr/local/lib/python3.7/site-packages/aioamqp/protocol.py", line 250, in get_frame
eventbus_1 | 2019-09-18 15:51:03.336 [info] <0.223.0> Peer discovery backend rabbit_peer_discovery_classic_config does not support registration, skipping randomized startup delay.
eventbus_1 | 2019-09-18 15:51:03.336 [info] <0.223.0> All discovered existing cluster peers:
eventbus_1 | 2019-09-18 15:51:03.337 [info] <0.223.0> Discovered no peer nodes to cluster with
eventbus_1 | 2019-09-18 15:51:03.362 [info] <0.43.0> Application mnesia exited with reason: stopped
spark_1 | 2019/09/18 16:00:20 ERROR brewblox_devcon_spark.seeder Incompatible firmware version detected
history_1 | return await amqp_frame.read(self._stream_reader)
eventbus_1 | 2019-09-18 15:51:04.140 [info] <0.223.0> Waiting for Mnesia tables for 30000 ms, 9 retries left
eventbus_1 | 2019-09-18 15:51:04.294 [info] <0.223.0> Waiting for Mnesia tables for 30000 ms, 9 retries left
traefik_1 | 2019/09/18 16:00:18 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:00:25 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:00:35 command traefik error: failed to decode configuration from flags: field not found, node: c
history_1 | File "/usr/local/lib/python3.7/site-packages/aioamqp/frame.py", line 78, in read
traefik_1 | 2019/09/18 16:00:43 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:00:56 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:01:08 command traefik error: failed to decode configuration from flags: field not found, node: c
history_1 | data = await reader.readexactly(7)
traefik_1 | 2019/09/18 16:01:27 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:01:56 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:02:50 command traefik error: failed to decode configuration from flags: field not found, node: c
history_1 | File "/usr/local/lib/python3.7/asyncio/streams.py", line 679, in readexactly
traefik_1 | 2019/09/18 16:03:52 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:04:55 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:05:57 command traefik error: failed to decode configuration from flags: field not found, node: c
eventbus_1 | 2019-09-18 15:51:04.502 [info] <0.223.0> Waiting for Mnesia tables for 30000 ms, 9 retries left
history_1 | await self._wait_for_data('readexactly')
eventbus_1 | 2019-09-18 15:51:04.504 [info] <0.223.0> Peer discovery backend rabbit_peer_discovery_classic_config does not support registration, skipping registration.
traefik_1 | 2019/09/18 16:06:59 command traefik error: failed to decode configuration from flags: field not found, node: c
history_1 | File "/usr/local/lib/python3.7/asyncio/streams.py", line 473, in _wait_for_data
eventbus_1 | 2019-09-18 15:51:04.505 [info] <0.223.0> Running boot step database_sync defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.506 [info] <0.223.0> Running boot step feature_flags defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.509 [info] <0.223.0> Running boot step codec_correctness_check defined by app rabbit
history_1 | await self._waiter
eventbus_1 | 2019-09-18 15:51:04.509 [info] <0.223.0> Running boot step external_infrastructure defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.510 [info] <0.223.0> Running boot step rabbit_registry defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.512 [info] <0.223.0> Running boot step rabbit_auth_mechanism_cr_demo defined by app rabbit
history_1 | concurrent.futures._base.CancelledError
eventbus_1 | 2019-09-18 15:51:04.514 [info] <0.223.0> Running boot step rabbit_queue_location_random defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.516 [info] <0.223.0> Running boot step rabbit_event defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.517 [info] <0.223.0> Running boot step rabbit_auth_mechanism_amqplain defined by app rabbit
history_1 | 2019/09/18 15:56:16 INFO brewblox_service.events Closing <EventListener for "eventbus">
eventbus_1 | 2019-09-18 15:51:04.519 [info] <0.223.0> Running boot step rabbit_auth_mechanism_plain defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.520 [info] <0.223.0> Running boot step rabbit_exchange_type_direct defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.521 [info] <0.223.0> Running boot step rabbit_exchange_type_fanout defined by app rabbit
traefik_1 | 2019/09/18 16:08:02 command traefik error: failed to decode configuration from flags: field not found, node: c
history_1 | 2019/09/18 15:56:16 INFO brewblox_service.events Closing <EventPublisher for "eventbus">
traefik_1 | 2019/09/18 16:09:05 command traefik error: failed to decode configuration from flags: field not found, node: c
eventbus_1 | 2019-09-18 15:51:04.522 [info] <0.223.0> Running boot step rabbit_exchange_type_headers defined by app rabbit
history_1 | ======== Running on http://0.0.0.0:5000 ========
traefik_1 | 2019/09/18 16:10:07 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:11:10 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:12:12 command traefik error: failed to decode configuration from flags: field not found, node: c
history_1 | (Press CTRL+C to quit)
traefik_1 | 2019/09/18 16:13:15 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:14:17 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:15:20 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:16:22 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:17:25 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:18:27 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:19:29 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:20:32 command traefik error: failed to decode configuration from flags: field not found, node: c
eventbus_1 | 2019-09-18 15:51:04.524 [info] <0.223.0> Running boot step rabbit_exchange_type_topic defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.524 [info] <0.223.0> Running boot step rabbit_mirror_queue_mode_all defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.525 [info] <0.223.0> Running boot step rabbit_mirror_queue_mode_exactly defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.527 [info] <0.223.0> Running boot step rabbit_mirror_queue_mode_nodes defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.528 [info] <0.223.0> Running boot step rabbit_priority_queue defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.528 [info] <0.223.0> Priority queues enabled, real BQ is rabbit_variable_queue
eventbus_1 | 2019-09-18 15:51:04.529 [info] <0.223.0> Running boot step rabbit_queue_location_client_local defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.530 [info] <0.223.0> Running boot step rabbit_queue_location_min_masters defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.531 [info] <0.223.0> Running boot step kernel_ready defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.531 [info] <0.223.0> Running boot step rabbit_sysmon_minder defined by app rabbit
eventbus_1 | 2019-09-18 15:51:04.532 [info] <0.223.0> Running boot step rabbit_epmd_monitor defined by app rabbit
traefik_1 | 2019/09/18 16:21:34 command traefik error: failed to decode configuration from flags: field not found, node: c
eventbus_1 | 2019-09-18 15:51:04.546 [info] <0.223.0> Running boot step guid_generator defined by app rabbit
traefik_1 | 2019/09/18 16:22:37 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:23:39 command traefik error: failed to decode configuration from flags: field not found, node: c
history_1 | 2019/09/18 16:00:09 INFO brewblox_service.service Creating [history] application
traefik_1 | 2019/09/18 16:24:42 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:25:44 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:26:47 command traefik error: failed to decode configuration from flags: field not found, node: c
history_1 | 2019/09/18 16:00:09 INFO brewblox_service.events Deferred event bus subscription: [<# @ brewcast>]
traefik_1 | 2019/09/18 16:27:49 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:28:52 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:29:54 command traefik error: failed to decode configuration from flags: field not found, node: c
history_1 | 2019/09/18 16:00:11 INFO brewblox_service.service Service info: 0.9.0-34-gae61b31 @ Tue Sep 3 09:20:57 UTC 2019
traefik_1 | 2019/09/18 16:30:56 command traefik error: failed to decode configuration from flags: field not found, node: c
traefik_1 | 2019/09/18 16:31:59 command traefik error: failed to decode configuration from flags: field not found, node: c
