Relevant links:
Edge release 2020/04/02
Firmware release date: 2020/04/02
We’re happy to announce the release of the Logic Actuator block.
You can use this block to toggle a Digital Actuator based on the state of other Digital Actuator, Motor Valve, Setpoint, or PWM blocks.
For a more in-depth explanation, see the blocks page.
To assist with this feature, we also added the Mock Pins block, and constraints for delaying the ON or OFF switch on digital actuators.
A less noticeable change is that we now build all our Docker images to be suitable for both AMD64 desktop computers and the ARM32 Raspberry Pi.
Previously, we prefixed Pi image tags with rpi-. This is no longer required.
To prevent breakage, we now tag the universally compatible images both with and without prefix.
This change will make it possible to move your system between a desktop computer and a Pi without having to make any changes to configuration.
Changes
- Added Logic Actuator block.
- Added Mock Pins block.
- Added Delay ON and Delay OFF digital constraints.
- Made all Docker images multiplatform, removing the need for
rpi-prefixes. - Updated Spark system libraries.
- Fixed a bug where controllers would stop being discoverable over Wifi.
- Added support for value fluctuations in Temp Sensor (Mock).
brewblox-ctl backup loadnow reads the values from the loaded .env file before loading databases and Spark services.- You can disable this with the
--no-load-envoption.
brewblox-ctl backup loadnow restarts Spark services to make sure they use the correct block names. -
brewblox-ctl setupnow uses a Docker container to generate SSL certificates. The host no longer needs to have OpenSSL installed. This was an issue for installing the system on Mac hosts. - Fixed a bug where the graph in Setpoint Profile was not updated if the block settings were changed in a different widget.
- The firmware simulator is now embedded in the Spark service Docker image. This is a first step towards having a demo setup that does not need a controller. For now this only works on amd64 (desktop) computers. We’re still working on getting the firmware to compile an ARM simulator.
- Fixed a bug where DS2408 / DS2413 chips could not be removed in the UI.
