Hi All, I am working on some changes to utilize RTDs’ instead of the One Wire sensors and am running into issues while trying to compile the binary. I get the same error even on a clean clone of the develop branch both using make clean.
This is the error using bash:
/usr/bin/sh: -c: line 0: syntax error near unexpected token (' /usr/bin/sh: -c: line 0:C:/Program Files (x86)/GnuWin32/bin/make -e -C firmware/main APPDIR=C:/Users/Josh/brewpi/firmware '
make: *** [run_make] Error 1
Error using CMD:
make[1]: Entering directory C:/Users/Josh/Brewpi/firmware/platform/spark/firmwa re/main' make -C ../modules/photon/user-part clean 'head' is not recognized as an internal or external command, operable program or batch file. The system cannot find the file specified. The system cannot find the file specified. make[2]: Entering directory C:/Users/Josh/Brewpi/firmware/platform/spark/firmware/modules/photon/user-part' ../../../build/module.mk:83: *** target pattern contains no%. Stop.
make[2]: Leaving directory C:/Users/Josh/Brewpi/firmware/platform/spark/firmware/modules/photon/user-part’
make[1]: *** [clean_modules/photon/user-part] Error 2
make[1]: Leaving directory C:/Users/Josh/Brewpi/firmware/platform/spark/firmware/main’
make: *** [run_make] Error 2
Which version of make do you have?
I compile on both windows and linux without issues.
I assume you did install the embedded ARM toolchain? https://launchpad.net/gcc-arm-embedded
If we can assume the ARM toolchain is the same, it must be make that is the problem.
