Error fresh install on Rpi3
Hi
I got error installing brewpi on raspberry pi 3. Have followed your instructions.
Please help!
Regards
Kjenset
***** Done processing BrewPi dependencies *****
Disk usage is 34%, free disk space is 8.7G. Enough to install BrewPi
To accept the default answer, just press Enter.
The default is capitalized in a Yes/No question: [Y/n]
or shown between brackets for other questions: [default]
The time is currently set to Tue 8 Nov 13:08:55 UTC 2016. Is this correct? [Y/n]n
Current default time zone: 'Europe/Oslo’
Local time is now: Tue Nov 8 14:09:27 CET 2016.
Universal Time is now: Tue Nov 8 13:09:27 UTC 2016.
*** This script will first ask you where to install the brewpi python scripts and the web interface
Hitting ‘enter’ will accept the default option in [brackets] (recommended).
Any data in the following location will be ERASED during install!
Where would you like to install BrewPi? [/home/brewpi]: y
Installing script in /home/brewpi
Searching for default web install location…
Found /var/www/html
Where would you like to copy the BrewPi web files to? [/var/www/html]: y
Installing web interface in y
This path does not exist, would you like to create it? [Y/n] y
Creating directory…
***** Creating and configuring user accounts… *****
Enter new UNIX password: Retype new UNIX password: passwd: password updated successfully
***** Checking install directories *****
y already exists
***** Downloading most recent BrewPi codebase… *****
Cloning into ‘/home/brewpi’…
/home/pi/brewpi-tools/install.sh: line 275: cd: y: No such file or directory
fatal: could not create work tree dir ‘y’.: Permission denied
*** ERROR ERROR ERROR ERROR ERROR ***
See above lines for error message
Setup NOT completed
Please accept the defaults with the enter key instead of y.
It now tried to create a directory with the name y.
