Error setting Constant Mode with Spark [SOLVED]
Hi there,
Finally managed to finish the build and am trying to get my Spark up and running for a water test run. If I set beer or fridge constant mode if get the following errors in the logs:
Mar 15 2015 17:11:17 Unicode decode error: ‘utf8’ codec can’t decode byte 0xff in position 22: invalid start byte
Mar 15 2015 17:11:17 Line received was: L:["Mode Beer Const. ",“Beer --.- 25.1 ??”,“Fridge --.- 30.0 ??”,“Idling for 33m57”]
Any ideas ?
Strange, it looks like it is failing on the degree sign. Is this on a raspberry pi?
Can you check which version of simplejson you have installed?
First install pip:
sudo apt-get install build-essential python-dev python-pip
Then check the version:
pip freeze | grep simplejson
If it is older than mine (3.6.5) can you try if upgrading helps?
sudo pip install simplejson --upgrade
I will modify the installer to use pip for all python packages, so they are always up to date.
Wow they were much older on 2.5.2 even after a full apt update / upgrade on first build. I have updated to 3.6.5. strangely I rebooted the Pi after posting the error and it seemed to kick it all into life.
It is now running a sample profile and seems to be heating the fridge / water so will run it for a while and see what we get !
I am having the same error, but my version is yours:
Mar 28 2015 22:09:06 Unicode decode error: 'utf8' codec can't decode byte 0xff in position 22: invalid start byte
Mar 28 2015 22:09:06 Line received was: L:["Mode Beer Const. ","Beer 20.3 5.0 ??","Fridge 20.8 1.0 ??","Idling for 15m43"]
Version:
simplejson==3.6.5
But i get also ean error when i try to get the verison:
pi@brewpi ~ $ pip freeze | grep simplejson
Warning: cannot find svn location for distribute==0.6.24dev-r0
simplejson==3.6.5
I get the same error for distribute, but it is given the correct version for simplejson as is yours.
I found that the USB cable was quite sat in correctly so I shutdown the Pi and Spark and reseated the cable, and then booted both. I boot the Pi first and then the Spark and it then started to work
Thanks Mark for the tip.
I tried the procedure (switching off, checking cable, rebooting), but nothing changed.
Just a thought and I have no idea if this will fix it, but I also changed the setting in default.cfg to be Core as the board type.
/home/brewpi/settings/default.cfg
scriptPath = /home/brewpi/
wwwPath = /var/www/
port = /dev/ttyACM0
altport = /dev/ttyACM1
boardType = Core
beerName = My First BrewPi Run
interval = 120.0
dataLogging = active
I had exactly the same problem and cured it by going to advanced settings in the web management and sending the Celsius setting to the Brewspark.
I had assumed that because “C” was shown in the box that it was set, but pressing the button beside it cured it for me.
Cool! That solved the problem for me too! Thanks!
