Hi! Installed brewblox for the first time in a new rbpi following the documentation steps. There were some hiccups when updating the packages, but after brewblox was apparently installed without problems.
But when after I tried to run the spark simulation I got some errors after running brewblox-ctl up
. This is the first and then some other exceptions follow:
File “/home/pi/brewblox/.venv/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 699, in urlopen
httplib_response = self._make_request(
File “/home/pi/brewblox/.venv/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File “/usr/lib/python3.9/http/client.py”, line 1255, in request
self._send_request(method, url, body, headers, encode_chunked)
File “/usr/lib/python3.9/http/client.py”, line 1301, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File “/usr/lib/python3.9/http/client.py”, line 1250, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.9/http/client.py”, line 1010, in _send_output
self.send(msg)
File “/usr/lib/python3.9/http/client.py”, line 950, in send
self.connect()
File “/home/pi/brewblox/.venv/lib/python3.9/site-packages/docker/transport/unixconn.py”, line 30, in connect
sock.connect(self.unix_socket)
ConnectionRefusedError: [Errno 111] Connection refused
Already re-formated the SD card and tried again, but encountered the same problem. A pointer in the right direction would be very appreciated…
Thanks!
