Just as FYI - I did a new brew with the latest update and I got an “event bus” error. Just wanted to log it in case you want to take look. Temps & everything seem fine though other than that.
Where did you get the error? I’m seeing a single startup error in the spark logs, but that’s it.
It flashed up in the GUI when I switched over to look at it from another program.
Ah ok. The browser closes persistent connections if you unfocus the page for a while.
When you tabbed back in, it likely showed an error about the lost connection, and then reconnected, causing the error to disappear.
