Mine works without any problems. If the sensors get hot this usually means they are wired wrong, at least according to my experience. No external Power is needed.
What kind of wire did you use to connect the Spark to the extension board? Does the extension bord light up once you connected it to the Spark?
How strong is the power supply for your raspberry?
Can you share a photo of the bad solder connection?
For the cable connecting board to Spark, are both sides identical? Make a photo of those next to each other too.
The sensors are working fine when plugged directly into the BrewPi.
I am using a Linux server for the Web interface instead of a rasberrypi.
Nothing on the expansion board lights up when plugged in. I bought a pre made, 6 conductor, Phone cable to connect to the BrewPi.
Here are the pictures of the cable and expansion board. After taking a closer look at the cable I see that it only has four conductors and the pinouts are different at each end.
I checked all the connectors on the board and none of them are shorted together. Is there a wiring diagram for the expansion board that I can follow?
Do you have a network tool and some RJ12 ends? If so, I’d just cut one of the ends off and put a new RJ12 cap on but rotate it 180º. Like @Dan said, it looks like the heads are just not aligned properly for your application.
Thanks guys, I rewired the cable and now the expansion board lights up and is detected in the device list. No more problems with temp sensors getting hot either.
If your connector is not soldered on the board properly, I should send you a new board. It will probably work, but it’s not the quality I’d like to deliver.
