I tried to upgrade this afternoon and ran into an issue where the update fails with an error. The UI loads but nothing works. Everything on the Spark seems to have gotten renamed to “New___”
Update:
pi@brewblox:~/brewblox $ brewblox-ctl update
Do you want to remove old docker images to free disk space? [Y/n]: n
INFO Updating brewblox-ctl…
INFO Updating brewblox-ctl libs…
Digest: sha256:eefc7b1534c8f3b7e76c17e9bef85167ace8495456a310846d0e5ba37b6d8c43
Status: Image is up to date for brewblox/brewblox-ctl-lib:edge
cd6a9e4460225645441923488d443b3a49b8874fe50f2479ff2052113284ab83
ctl-lib
INFO Checking Avahi config…
INFO Stopping services…
Stopping brewblox_history_1 … done
Stopping brewblox_traefik_1 … done
Stopping brewblox_redis_1 … done
Stopping brewblox_influx_1 … done
Stopping brewblox_eventbus_1 … done
Stopping brewblox_ui_1 … done
Stopping brewblox_tilt_1 … done
Stopping brewblox_fermenter1_1 … done
Removing brewblox_redis_1 … done
Removing brewblox_eventbus_1 … done
Removing brewblox_ui_1 … done
Removing brewblox_tilt_1 … done
Removing brewblox_fermenter1_1 … done
INFO Migrating configuration files…
INFO Removing depends_on fields from docker-compose.yml…
INFO Creating redis/ dir…
INFO Checking .env variables…
INFO Pulling docker images…
Pulling eventbus … done
Pulling traefik … done
Pulling history … done
Pulling influx … done
Pulling fermenter1 … done
Pulling tilt … done
Pulling ui … done
Pulling redis … done
INFO Starting services…
Creating brewblox_ui_1 … done
Creating brewblox_history_1 … done
Creating brewblox_traefik_1 … done
Creating brewblox_tilt_1 … done
Creating brewblox_eventbus_1 … done
Creating brewblox_influx_1 … done
Creating brewblox_redis_1 … done
Creating brewblox_fermenter1_1 … done
INFO Migrating service configuration…
Connecting https://localhost:443/history/history/ping, attempt 1/60
Connecting https://localhost:443/history/history/ping, attempt 2/60
Connecting https://localhost:443/history/history/ping, attempt 3/60
Success!
INFO Migrating datastore from CouchDB to Redis…
INFO Starting a temporary CouchDB container on port 5984…
318453cf95f3566367a8f32ca91cb50690021735f22e1cccfa65c3ba441667f9
Connecting http://localhost:5984, attempt 1/60
Connecting http://localhost:5984, attempt 2/60
Connecting http://localhost:5984, attempt 3/60
Connecting http://localhost:5984, attempt 4/60
Connecting http://localhost:5984, attempt 5/60
Connecting http://localhost:5984, attempt 6/60
Connecting http://localhost:5984, attempt 7/60
Success!
Connecting https://localhost:443/history/datastore/ping, attempt 1/60
Success!
500 Server Error: Internal Server Error for url: https://localhost:443/history/datastore/mset
Command ‘/usr/bin/python3 /home/pi/.local/bin/brewblox-ctl update --update-ctl-done --no-prune’ returned non-zero exit status 1.
