I checked on my fermentation this morning and found that the set point for my beer had changed on its. own. I had it set to 46, and it is now set to 65.4 It looks like the change happened only a couple of hours ago.
Attached are 2 images of the dashboard and the api error log. From the images you can see the set point in the active profile is still 46, but the fridge is somehow set independent of the profile. How can I fix this?
How long had it been running without rebooting? I’m wondering whether it could be an overflow of the time keeping.
Also, why don’t you change the start time of the profile instead of having offsets over 100 days?
I think I see a small ramp up in the setting. So this definitely looks like a bug in the calculation when time overflows.
The part at 65.4, looks like it repeated the start of the profile.
It has been on for a couple of months without a reboot.
I didn’t change the start time beacuse it was easier to just go in and add a new setpoint for the current time.I could reboot at the end/start of each ferementation and probably take care of this.
It should be fixed in firmware. The system milliseconds since boot timer overflows after 49 days. I’ll write some test cases and a fix.
But if you have not rebooted in 49 days, you also have not updated in 49 days. We release new firmware regularly and I recommend staying up to date to get the latest fixes.
