I’ve been using the new Brewpi since before the update to the internal state machine. Since the update (0.4.3) I’m seeing quite a big of overshoot when the initial temperature is set and on subsequent changes. Any ideas what changes I need to make to the PID values for the various actuators? Currently using all defaults.
In the example below, I start at 19C, raise to 20 after 4 days, then subsequently raise to 20.2 and 20.4 to try and minimise the swing.
Environment
Fridge with ceremic 40W heating bar.
Graph
Configuration
"kind": "Control",
"pids": [
"kind": "Pid",
"name": "heater1",
"enabled": true,
"setPoint": {
"kind": "SetPointSimple",
"name": "fridgeset",
"value": 9
"inputSensor": {
"kind": "TempSensorFallback",
"onBackupSensor": false,
"sensor": {
"kind": "TempSensor",
"name": "fridge",
"sensor": {
"kind": "OneWireTempSensor",
"value": 23.25,
"connected": true,
"address": "280FD4730600008A",
"calibrationOffset": 0
"inputError": 14.25,
"Kp": 10,
"Ti": 600,
"Td": 0,
"p": -142.5,
"i": 0,
"d": 0,
"actuatorIsNegative": false,
"outputActuator": {
"kind": "ActuatorPwm",
"value": 0,
"period": 4,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"kind": "ActuatorMutexGroup",
"deadTime": 1800000,
"waitTime": 0
"target": {
"kind": "ActuatorPin",
"state": false,
"pin": 10,
"invert": false
"kind": "Pid",
"name": "heater2",
"enabled": true,
"setPoint": {
"name": "beer2set",
"value": null
"inputSensor": {
"name": "beer2",
"sensor": {
"value": 22.3125,
"connected": true,
"address": "2814A273060000D8",
"inputError": null,
"Kp": 10,
"Ti": 600,
"Td": 0,
"p": 0,
"i": 0,
"d": 0,
"outputActuator": {
"value": 0,
"period": 4,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"waitTime": 0
"target": {
"kind": "ActuatorNop",
"state": false
"kind": "Pid",
"name": "cooler",
"enabled": true,
"setPoint": {
"value": 9
"inputSensor": {
"sensor": {
"name": "fridge",
"sensor": {
"value": 23.25,
"connected": true,
"Kp": 10,
"Ti": 1800,
"Td": 0,
"p": -142.5,
"i": 0,
"d": 0,
"actuatorIsNegative": true,
"outputActuator": {
"value": 100,
"period": 1200,
"minVal": 0,
"maxVal": 100,
"target": {
"mutexGroup": {
"waitTime": 0
"target": {
"minOnTime": 120,
"minOffTime": 180,
"maxOnTime": 65535,
"state": false,
"target": {
"state": false,
"pin": 11,
"invert": false
"kind": "Pid",
"name": "beer2fridge",
"enabled": true,
"setPoint": {
"name": "beer1set",
"value": 19
"inputSensor": {
"name": "beer1",
"sensor": {
"value": 24.5625,
"connected": true,
"address": "28389573060000C6",
"inputError": 5.7148,
"Kp": 2,
"Ti": 7200,
"Td": 0,
"p": -11.4297,
"i": -0.0078,
"d": 0,
"outputActuator": {
"kind": "ActuatorSetPoint",
"targetSetPoint": {
"value": 9
"targetSensor": {
"name": "fridge",
"sensor": {
"value": 23.25,
"connected": true,
"referenceSetPoint": {
"name": "beer1set",
"value": 19
"output": -10,
"achieved": 4.25,
"minimum": -10,
"maximum": 10
