Hello Bob,
Trying to do a fresh install but I run into this error:
right@right:~ $ wget -qO - https://www.brewblox.com/install | bash
INFO Installing uv
downloading uv 0.6.3 arm-unknown-linux-musl-staticeabihf
no checksums to verify
installing to /home/right/.local/bin
uv
uvx
everything’s installed!
To add $HOME/.local/bin to your PATH, either restart your shell or run:
source $HOME/.local/bin/env (sh, bash, zsh)
source $HOME/.local/bin/env.fish (fish)
WARNING: The following commands are shadowed by other commands in your PATH: uv uvx
INFO Brewblox dir is “/home/right/brewblox”
INFO Brewblox release is “edge”
INFO Creating Python virtual env…
Using CPython 3.11.2 interpreter at: /usr/bin/python
Creating virtual environment at: .venv
Activate with: source .venv/bin/activate
INFO Installing Python packages…
Resolved 1 package in 80ms
Prepared 1 package in 234ms
Installed 1 package in 29ms
- pip==25.0.1
Looking in indexes: Simple index, piwheels - Simple index
Collecting git+https://github.com/brewblox/brewblox-ctl@edge
Cloning GitHub - BrewBlox/brewblox-ctl: Management and configuration menu for BrewBlox users (to revision edge) to /tmp/pip-req-build-6f_dn1ld
ERROR: Error [Errno 2] No such file or directory: ‘git’ while executing command git version
ERROR: Cannot find command ‘git’ - do you have ‘git’ installed and in your PATH?
right@right:~ $ brewblox-ctl
-bash: brewblox-ctl: command not found
