I am currently doing a fresh install to get up to date but am running into an issue when running the installation script. I am using the latest raspberry pi os lite. I followed the “Getting Started” guide so everything is up to date. Ive pasted the build error below.
` Building wheel for bcrypt (PEP 517) … error
ERROR: Command errored out with exit status 1:
command: /home/pi/brewblox/.venv/bin/python3 /tmp/tmpso38u_lp_in_process.py build_wheel /tmp/tmpg3pclrer
cwd: /tmp/pip-install-mbkqj33o/bcrypt_e3bfa3a19fdc4c17aa0f7bcb6a74f65d
Complete output (58 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-cpython-39
creating build/lib.linux-armv7l-cpython-39/bcrypt
copying src/bcrypt/init.py → build/lib.linux-armv7l-cpython-39/bcrypt
copying src/bcrypt/about.py → build/lib.linux-armv7l-cpython-39/bcrypt
running egg_info
writing src/bcrypt.egg-info/PKG-INFO
writing dependency_links to src/bcrypt.egg-info/dependency_links.txt
writing requirements to src/bcrypt.egg-info/requires.txt
writing top-level names to src/bcrypt.egg-info/top_level.txt
reading manifest file ‘src/bcrypt.egg-info/SOURCES.txt’
reading manifest template ‘MANIFEST.in’
warning: no previously-included files found matching ‘requirements.txt’
warning: no previously-included files found matching ‘release.py’
warning: no previously-included files found matching ‘mypy.ini’
warning: no previously-included files matching ‘’ found under directory ‘.github’
warning: no previously-included files matching '’ found under directory ‘.circleci’
warning: no previously-included files found matching ‘src/_bcrypt/target’
warning: no previously-included files matching ‘*’ found under directory ‘src/_bcrypt/target’
adding license file ‘LICENSE’
writing manifest file ‘src/bcrypt.egg-info/SOURCES.txt’
copying src/bcrypt/_bcrypt.pyi → build/lib.linux-armv7l-cpython-39/bcrypt
copying src/bcrypt/py.typed → build/lib.linux-armv7l-cpython-39/bcrypt
running build_ext
running build_rust
=============================DEBUG ASSISTANCE=============================
If you are seeing a compilation error please try the following steps to
successfully install bcrypt:
1) Upgrade to the latest pip and try again. This will fix errors for most
users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
2) Ensure you have a recent Rust toolchain installed. bcrypt requires
rustc >= 1.56.0.
Python: 3.9.2
platform: Linux-5.15.61-v7+-armv7l-with-glibc2.31
pip: n/a
setuptools: 65.4.0
setuptools_rust: 1.5.2
rustc: n/a
error: can’t find Rust compiler
If you are using an outdated pip version, it is possible a prebuilt wheel is available for this package but pip is not able to install from it. Installing from the wheel would avoid the need for a Rust compiler.
To update pip, run:
pip install --upgrade pip
and then retry package installation.
If you did intend to build this package from source, try installing a Rust compiler from your system package manager and ensure it is on the PATH during installation. Alternatively, rustup (available at https://rustup.rs) is the recommended way to download and update the Rust compiler toolchain.
This package requires Rust >=1.56.0.
ERROR: Failed building wheel for bcrypt
Successfully built brewblox-ctl
Failed to build bcrypt
ERROR: Could not build wheels for bcrypt which use PEP 517 and cannot be installed directly`
