Get or set IP Adress on Spark 3
At the end of the installation, I used the commands
brewblox-ctl flash
brewblox-ctl wifi
Unfortunately I can’t get a Wifi connection to spark3
pi@raspberrypi:~/brewblox $ brewblox-ctl wifi
INFO Pulling flasher image…
Digest: sha256:ac8c5180d4f4cb9adbe39587b39caf1df99ed1e5b13341225ded750866c244c2
INFO Stopping services…
INFO Configuring wifi…
â
â
â
â
â
â
Wifi to Raspberry 4 works. What do I have to do to use Wifi on Spark3?
Is the controller blinking blue during the wifi command?
If it’s not, you can run the following commands:
brewblox-ctl particle
particle usb safe-mode
bash wifi
exit
During “bash wifi”, you will be asked for your SSID/password.
If the controller is currently slowly blinking blue, power cycle it first.
Hi Bob
With your help it works now. Thank you!
Cheers!
