To fix that history error, edit your docker-compose.yml file, and add under services:
history:
privileged: true
Then run brewblox-ctl up
The issue is also resolved with the latest Raspberry Pi OS, but that would require a fresh install. This is simpler.
We’ll look at a more permanent fix in the morning.
rfinley
22
I’m not sure where to find the docker-compose.yml file to edit it, so to be continued tomorrow.
Thanks for the help !!
Elco
23
It’s in the brewblox directory, where you also run brewblox-ctl…
You can edit it with nano docker-compose.yml
rfinley
24
It is back to normal !! Spark looks normal, no disappearing temps.
You guys are the best !!! Thank You !!
