Having another proble?
Getting ready to use my cooler as a refrigerator for Thanksgiving and Its have trouble maintaining 40 degf. I’m attaching a short video of what the Spark display is doing… I have disconnected the temperature sensors one at a time and it is still doing this. I have restarted the Spark and the RaspberyPi.
Any ideas ???
https://drive.google.com/file/d/1NaE03l0T3J-ClivQ5uk9JouBRUTndX2_/view?usp=sharing
It looks like either controller hangups, or periodically disconnecting sensors. Could you please run brewblox-ctl log?
https://termbin.com/i4lo5
It looks like something is causing errors in onewire communication.
I have seen this in the past because of very long onewire cables or a noisy VFD controlling a pump, causing electromagnetic interference.
If you have 2 onewire sensors running in opposite directions, this could maybe make the problem worse by forming dipole antenna.
All are standard length, maybe 4’ ?? Purchased when I purchased the Spark. The beer and fridge both go into the cooler. Room temp is coiled up on top of the controller. No VFD’s…
Are the sensors continuously lost a come back?
If you try them one by one, is that still the case?
What if you disconnect the 2413/2408 boards?
I have disconnected each sensor one at a time and it dose the same as the video. Each sensor reads +or - .2 DEGF of each other. Not sure what boards you are referring to.
Ah, my fault. Those boards were on the simulator.
So it’s just a spark with 3 sensors plugged in. That’s strange.
We did release an update today. I don’t think it will make a difference, because we didn’t change related things, but please try updating to the latest version just to be sure.
brewblox-ctl update
I believe will do it ??
yes, that should do it. Then afterwards, update the controller through the web interface (it will give a popup).
Seems to have went well but when I try to start the web page I get this…
Your services are not running.
Run brewblox-ctl up or to ensure the update was not half finished, run brewblox-ctl update again
Did update then brewblox-ctl up still show waiting for data store…
Share another log file please.
https://termbin.com/v9xc
Can you try this?
brewblox-ctl fix ipv6 and reboot?
Did above, still waiting for datastore.
https://termbin.com/6d62
What is the output of:
docker-compose ps?
@Bob_Steers looks like the permission error on the monotonic clock in history service is still causing problems.
@rfinley I think you need Bob to fix this. The history service is restarting due to the bug and maybe this is causing the other issues.
