- * Copyright 2012-2013 BrewPi/Elco Jacobs.
- * This file is part of BrewPi.
- * BrewPi is free software: you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation, either version 3 of the License, or
- * (at your option) any later version.
- * BrewPi is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with BrewPi. If not, see <http://www.gnu.org/licenses/>.
- #include "Brewpi.h"
- #include "temperatureFormats.h"
- #include "Board.h"
- #include "TempControl.h"
- #include "PiLink.h"
- #include "Ticks.h"
- #include "TempSensor.h"
- #include "TempSensorMock.h"
- #include "TempSensorDisconnected.h"
- #include "ModeControl.h"
- #include "EepromManager.h"
- #include "defaultDevices.h"
- #define DISABLED_TEMP temp_t::disabled()
- TempControl tempControl;
- ControlConstants const ccDefaults =
- // Do Not change the order of these initializations!
- 'C', // tempFormat
- 30.0, // heater1_kp
- 1800, // heater1_ti
- 60, // heater1_td
- 1, // heater1_infilt
- 4, // heater1_dfilt
- 30.0, // heater2_kp
- 1800, // heater2_ti
- 60, // heater2_td
- 1, // heater2_infilt
- 4, // heater2_dfilt
- 20.0, // cooler_kp
- 3600, // cooler_ti
- 300, // cooler_td
- 1, // cooler_infilt
- 4, // cooler_dfilt
- 5.0, // beer2fridge_kp
- 10800, // beer2fridge_ti
- 600, // beer2fridge_td
- 1, // beer2fridge_infilt
- 4, // beer2fridge_dfilt
- 6.0, // beer2fridge_pidMax
- 120, // minCoolTime
- 180, // minCoolIdleTime
- 4, // heater1PwmPeriod
- 4, // heater2PwmPeriod
- 1200, // coolerPwmPeriod
- 1800, // mutexDeadTime
- TempControl::TempControl()
- // set to -1800 so that at boot, the controller does not think it is in PWM idle period
- lastHeatTime = -1800;
- lastCoolTime = 0;
- lastIdleTime = 0;
- tcduration_t TempControl::timeSinceCooling(void)
- return ticks.timeSinceSeconds(lastCoolTime);
- tcduration_t TempControl::timeSinceHeating(void)
- return ticks.timeSinceSeconds(lastHeatTime);
- tcduration_t TempControl::timeSinceIdle(void)
- return ticks.timeSinceSeconds(lastIdleTime);
- void TempControl::loadDefaultSettings()
- #if BREWPI_EMULATE
- setMode(MODE_BEER_CONSTANT, false);
- #else
- setMode(MODE_TEST, false);
- #endif
- setBeerTemp(DISABLED_TEMP, false); // start with no temp settings
- setFridgeTemp(DISABLED_TEMP, false);
- void TempControl::storeConstants(eptr_t offset)
- eepromAccess.writeBlock(offset, (void *) &cc, sizeof(ControlConstants));
- updateConstants();
- void TempControl::loadConstants(eptr_t offset)
- eepromAccess.readBlock((void *) &cc, offset, sizeof(ControlConstants));
- // write new settings to EEPROM to be able to reload them after a reset
- // The update functions only write to EEPROM if the value has changed
- void TempControl::storeSettings(eptr_t offset)
- eepromAccess.writeBlock(offset, (void *) &cs, sizeof(ControlSettings));
- storedBeerSetting = cs.beerSetting;
- void TempControl::loadSettings(eptr_t offset)
- eepromAccess.readBlock((void *) &cs, offset, sizeof(ControlSettings));
- logDebug("loaded settings");
- setMode(cs.mode, false);
- setBeerTemp(cs.beerSetting, false);
- setFridgeTemp(cs.fridgeSetting, false);
- void TempControl::loadDefaultConstants(void)
- memcpy((void *) &tempControl.cc, (void *) &ccDefaults, sizeof(ControlConstants));
- void TempControl::setMode(char newMode,
- bool store)
- logDebug("TempControl::setMode from %c to %c", cs.mode, newMode);
- if (newMode == MODE_OFF)
- setBeerTemp(DISABLED_TEMP, true);
- setFridgeTemp(DISABLED_TEMP, true);
- control.heater1Pid.disable(true);
- control.coolerPid.disable(true);
- control.beerToFridgePid.disable(false);
- else if (newMode == MODE_BEER_CONSTANT || newMode == MODE_BEER_PROFILE){
- control.heater1Pid.enable();
- control.coolerPid.enable();
- control.beerToFridgePid.enable();
- else if (newMode == MODE_FRIDGE_CONSTANT){
- cs.mode = newMode;
- if(store){
- eepromManager.storeTempSettings();
- void TempControl::setBeerTemp(temp_t newTemp, bool store) {
- control.beer1Set.write(newTemp);
- cs.beerSetting = newTemp;
- if (store && ((cs.mode != MODE_BEER_PROFILE) ||
- (storedBeerSetting - newTemp) > temp_t(0.25) ||
- (newTemp - storedBeerSetting) > temp_t(0.25)))
- // more than 1/4 degree C difference with EEPROM
- // Do not store settings every time in profile mode, because EEPROM has limited number of write cycles.
- // A temperature ramp would cause a lot of writes
- // If Raspberry Pi is connected, it will update the settings anyway. This is just a safety feature.
- void TempControl::setFridgeTemp(temp_t newTemp, bool store) {
- control.fridgeSet.write(newTemp);
- cs.fridgeSetting = newTemp;
- if(store){
- control_mode_t ModeControl_GetMode()
- return tempControl.getMode();
- control_mode_t ModeControl_SetMode(control_mode_t mode)
- control_mode_t prev = tempControl.getMode();
- tempControl.setMode(mode, true);
- return prev;
- // loads settings in tempControl to control, overwriting all existing settings
- // This is temporary fix, until settings are stored elsewhere
- // Overwriting with the same value should not have any side effects
- // updating all settings when only one has changed is a temporary fix. TODO
- void TempControl::updateConstants()
- //settings for heater 1
- control.heater1Pid.Kp = cc.heater1_kp;
- control.heater1Pid.Ti = cc.heater1_ti;
- control.heater1Pid.Td = cc.heater1_td;
- //settings for heater 2
- control.heater2Pid.Kp = cc.heater2_kp;
- control.heater2Pid.Ti = cc.heater2_ti;
- control.heater2Pid.Td = cc.heater2_td;
- //settings for cooler
- control.coolerPid.Kp = cc.cooler_kp;
- control.coolerPid.Ti = cc.cooler_ti;
- control.coolerPid.Td = cc.cooler_td;
- //settings for beer2fridge PID
- control.beerToFridgePid.Kp = cc.beer2fridge_kp;
- control.beerToFridgePid.Ti = cc.beer2fridge_ti;
- control.beerToFridgePid.Td = cc.beer2fridge_td;
- control.coolerPwm.setPeriod(cc.coolerPwmPeriod);
- control.heater1Pwm.setPeriod(cc.heater1PwmPeriod);
- control.heater2Pwm.setPeriod(cc.heater2PwmPeriod);
- control.coolerTimeLimited.setTimes(cc.minCoolTime, cc.minCoolIdleTime);
- control.heater1Pid.setInputFilter(cc.heater1_infilt);
- control.heater1Pid.setDerivativeFilter(cc.heater1_dfilt);
- control.heater2Pid.setInputFilter(cc.heater2_infilt);
- control.heater2Pid.setDerivativeFilter(cc.heater2_dfilt);
- control.coolerPid.setInputFilter(cc.cooler_infilt);
- control.coolerPid.setDerivativeFilter(cc.cooler_dfilt);
- control.beerToFridgePid.setInputFilter(cc.beer2fridge_infilt);
- control.beerToFridgePid.setDerivativeFilter(cc.beer2fridge_dfilt);
- control.fridgeSetPointActuator.setMin(-cc.beer2fridge_pidMax);
- control.fridgeSetPointActuator.setMax(cc.beer2fridge_pidMax);
- control.mutex.setDeadTime(cc.mutexDeadTime * 1000);
This file has been truncated. show original
