Tried updater.py and a few other update instruction found in this topic to no avail. Still at 0.4.3 and experiencing the bug that locks the PID control mode Heat or cool on.
Here is the script after running updater.py
pi@hammondbrewpi:~/brewpi-tools $ sudo python updater.py
It is not recommended to update during a brew!
If you are actively logging a brew we recommend canceling the the update with ctrl-c.
Quit message sent to BrewPi instance with pid 1292!
You are on branch master
The latest commit in /home/brewpi is 2b3756d43988264c73be8a42fe39ee01285cec8e on Mon, 31 Jul 2017 13:01:57
The latest commit on origin/master is 2b3756d43988264c73be8a42fe39ee01285cec8e on Mon, 31 Jul 2017 13:01:57
The latest commit in /var/www/html is 2282837df5f0bb171ae58302b7780d5d50d213e2 on Sat, 23 Sep 2017 01:23:28
The latest commit on origin/master is 2282837df5f0bb171ae58302b7780d5d50d213e2 on Sat, 23 Sep 2017 01:23:28
Your local version of /var/www/html is up to date!
Dec 16 2017 16:51:27 Opening serial port
Found BrewPi v0.4.3 build 0.4.3-0-g4d00879, running on a Particle Photon with a V2 shield on port /dev/ttyACM0
Current firmware version on controller: 0.4.3
Latest version on GitHub: 0.5.2
Downloading firmware…
downloading https://github.com/BrewPi/firmware/releases/download/0.5.2/brewpi-photon-0.5.2.bin
Updated system firmware for the photon found in release 0.4.4
downloading https://github.com/BrewPi/firmware/releases/download/0.4.4/system-part1-0.5.3-photon.bin
downloading https://github.com/BrewPi/firmware/releases/download/0.4.4/system-part2-0.5.3-photon.bin
/home/brewpi/utils/downloads/0.4.4/system-part1-0.5.3-photon.bin
and
/home/brewpi/utils/downloads/0.4.4/system-part2-0.5.3-photon.bin
/home/brewpi/utils/downloads/0.5.2/brewpi-photon-0.5.2.bin
Updating firmware…
**** Photon Program script started ****
Dec 16 2017 16:51:32 Opening serial port
Checking current version: Found BrewPi v0.4.3 build 0.4.3-0-g4d00879, running on a Particle Photon with a V2 shield on port /dev/ttyACM0
Requesting old settings from Photon…
Saved old settings to file settings-Dec-16-2017-16-51-35.json
Flashing system part 1.
Triggering a firmware update with the ymodem protocol on the controller
Flashing file /home/brewpi/utils/downloads/0.4.4/system-part1-0.5.3-photon.bin
Problem flashing file: 67
Please try again.
BrewPi script will restart automatically.
Firmware update done
*** Done updating BrewPi! ***
