Using BrewBlox to control HERMS with gas burners. During pre-heat of the mash liquor, I can never hit my strike temp (within a reasonable time). With the burner at 100% heat, the system will raise temp steadily till within 2-3 of target. Then the software starts calling for less heat (to prevent overshoot I presume) such that it would take another 2-3 hours to reach target temp for the strike water.
For example, on the most recent brew with a target strike temp of 72C, heating started at 5AM with the following results:
5 AM = 5C
7 AM = 69C
8AM = 71C
From 5 AM - 7 AM, brewblox called for 100% heat. Then it started reducing heat % such that I think it would take another 2 hours to hit 72C. I am currently telling brewblox to control the temp of the MT.
Are there any configuration adjustments I can look at to better hit target strike temp of mash water?
