I have two 3 phase heating elements inside my tank, and I would like to control them using one single actuator. What’s the most sensible way to do that? Is using two channels in the GPIO module going to work?
I realized I was making a stupid mistake when wiring things together. It seems connecting the two SSR(s) to two channels of the GPIO in parallel works. Unless I this is in some way not recommended, I would say the issue is solved ![]()
This solution works just fine =)
