I’m having trouble sometimes when I had 2 Sparks powered at the same time.
They are both getting the correct IP address according to the DHCP address reservation in my router. The BrewBlox service for each device is using the correct IP address when they are powered individually but when they are both switched on sometimes both services are trying to connect to the 2 Sparks using one of the 2 IP addresses. Is there somewhere where I can manually set the IP address for a service?
