HI Elco,
Thanks for your reply,
I was unaware of the BrewBlox stack, it looks very promising
I will give it a try and see how I can contribute
Best regards
ben
Iāll add you on our Developer slack.
Hi there,
Does anyone know why I get the following error:
Error response from daemon: pull access denied for charliwest/brewpi-ispindel, repository does not exist or may require 'docker loginā
I have the latest brewpi Spark, all up to date.
Gāday Charliwest,
No unfortunately, not.
I have the ispindel outputting to a graph on ubidots, displaying temp and tilt. I can access this on the internet.
I tried to setup the brewpi so that I could access it on the internet (using a VPN) but couldnāt get it to work after many hours of trying.
So thereās no real advantage for me to incorporate ispindel to brewpi until (if ever) I can work out how to connect to brewpi via the Internet. I have ubidots as a bookmark, so it displays instantly anyway.
I only use the ispindel to check the relative SG (I did not calibrate it) to check if fermentation has kicked off, and when it flattens out, finished. I use a refractometer as itās fairly quick and easy to use. The temperature indications on the ispindel are very good too. The only issue that Iāve had with the ispindel is the USB charger connector snapping off, so I now charge the battery directly with a lipo battery charger that I use to charge my drones (I just soldered a connector onto it). It was just easier than desoldering the whole board and putting a new one on.
Regards
Cavok
I see this thread is pretty old, looking for some insight though. I have BrewPi legacy, followed all the instructions to add iSpindel to my BrewPi. I can see that its logging into the CSV but my BrewPi screen is blank.
Not quite sure what I did wrong, the instructions are pretty straightforward.
You could check if the brewpi container can access the csv file (is it mounted? what are permissions?)
Beyond that Iām afraid weāve discontinued support for the brewpi and brewpi legacy software.
By now, BrewBlox has fully replaced both - and it has a plugin for the iSpindel at https://github.com/bdelbosc/brewblox-ispindel.
