Bopti
1
Hello Brewpi community!
I have juste flashed my SD card with HypriotOS (v. 1.7.1) and everything is fine except that I can’t locate “device-init.yaml” file…
Can anyone tell me if it’s a hidden file or some kind? (It seems that I can’t even see /boot directory)
Should it be edited straight from the Raspberry or can we just edit the file from another computer? (I’m running a Mac)
Forgive that dumb question and my limited UNIX knowledge!
Many thanks!
Dave
Elco
2
The file can be found on the SD card from your mac, it is not in a subdirectory. If you want to access it from the pi, it is in the /boot dir.
Bopti
3
Hello Elco,
It’s very strange because there’s about thirty different files on the SD card but not the one we’re looking for…
So weird…
I could list the whole files if you want.
Hey Bopti,
Had the same problem here, but I downgraded to Hypiot 1.6 after which I was able to find the device-init.yaml file. Hope this helps you too!
Bopti
5
You’re right Limbrew! I had to do the same (it took me a day to figure out the problem!..)
Digital brewing is a long…long way!
Cheers!
