I’m brand new at this, so let me know if I’m not providing the right details.
I’m trying to install the BrewPi software on my Pi, and I’m having an issue that I haven’t seen discussed elsewhere. After running the following command:
If I type in a username, it then asks for a password, and since I don’t have either, the login fails.
I haven’t seen anywhere about needing a username or password to download the files from github, so where do I sign up for this, or what am I doing wrong?
Ok. I created an account at github, so I’ll try again when I get home and report back. I assumed I was doing something incorrectly, but I can’t find my mistake.
That’s what I meant, not sure whether it’s fluke or not but on occasion I’ve pastes a block of command and it’s worked where I’ve experienced issues having pasted 1 or 2 lines separately.
Chances are it might not work but it’s worth a try.
i had no issues getting Brewpi to work in terms of the rpi and brewpi software so unless Elco has made a change (I’m guessing his post earlier indicates he hasn’t) it should all work ok.
You could always try and reinstall raspian and brewpi from scratch if nothing else is on it yet.
