Last saturday I did my second brew since I upgraded my HERMS with lauterhexe filter to 70 liter pans. The first time the process went great except for a low efficiency, only 50%. To compensate for that this time I added more grain and becasue this beer is supposed to be stronger it was a lot of extra grain, 20 kg in total but it all fitted in the pans. (3.2 liters / kg grain)
I added the grain in the mashing pan and pumped the water on top of the grain. After a couple of minutes I stirred it all the prevent ‘dough balls’ . The stirring was hard work because it was a lot of grain
. After I let it settle for about 5 minutes.
Then I started the pump and it took just a few minutes and the flow was nearly zero. The grain at the bottom of the pan was super compact and no water flowed through.
So the whole mashing process we stirred like hell to get just a bit of flow to heat the mashing pan. We did find some dough balls while stirring.
Upside of this story is that because we stirred the hole process we got a really good efficiency, recipe was SG of 1080 and we got 1120
This is going to be a strong chouffe!
What do you guys think how to solve this issue?
- pump at lower speed
- add grain bit by bit to the water so it mixes really well and prevent dough balls
- add filter bottom
