The Logic Block seems to be a great tool.
I can see lots of uses for it given some time to sort out the rest of the service.
Oddly enough, first thing I set out to use it for was to implement a minimum temp in my freezer.
(If fridge >= -8*F, true)
This does not work as I expected.
It seems the measured value of a compared PWM is actually the “duty achieved” not the temp sensor further up its control chain.
This makes sense, it’s just that upon not finding a temp sensor as an option to select for comparison, I turned to the guide and found this under Logic Actuator:
Bis the Comparison for thePWM. It has a red indicator. Its measured value is below 25 °C, resulting in afalse.
I think if you changed “°C” to “%” in the guide, it would read appropriately.
Furthermore, also in that section, an example given for a comparison is:
beer temperature >= 20
I just found that temp sensor can be compared from a setting block!
