Hi All, Elco,
I received my BrewPi Spark 3 last week, and hacked my freezer this weekend. Very exciting, was a lot easier than i thought it was going to be.
I got my hands on a 430 litre upright feezer where all the shelves come out, so i can fit my large 60 litre fermenter in easily.
Having a freezer will be quite handy as i really want to try brewing a Eisbock.
I am however having a couple of issues.
I can’t work out how to change the minimum fridge set point. It seems that there is a setting in the advanced settings called Maximum difference between fridge and beer set point (= output of PID). The default value was 10. I am doing a trial now with just water, and i have the beer set to 14 c. I notice that the fridge set point is hovering around 4… presumably because of this setting not allowing a difference bigger than 10 degrees.
I changed it to 20 and clicked ‘Send to controller’ but it didn’t change the fridge set point…
Given i have a freezer, it would work much better at cooling the currently 17degree beer down if the fridge set point was -6 or even lower.
Is there a process that you need to follow when changing the setting so it gets used? -
When in hardware test mode, the touch button for actuator 1 doesn’t work. All the others work, but actuator 1, the button just flashes on then off again in a split second - like it barely has enough time to change the text in the button to say ON. you just see a tiny flicker of red on the button then back to OFF with black background. I can see it flicking the SSR on and off too because of the LED.
The actuator works fine when in profile mode. I am actually using that actuator for the cooling cycle and am not seeing any issues. It looks like an issue with the touch screen perhaps.
Cheers,
Mike
