Maximum Heating Time?
In the discussion, First Build: Which Heater to choose? http://forum.brewpi.com/discussion/728/first-build-which-heater-to-choose, there is a mention of “maximum heating time to my software to prevent it from shutting down”. Is this a parameter that can be configured in the software.
I am having a problems with the Lasko #100 heater, http://www.amazon.com/Lasko-100-MyHeat-Personal-Ceramic/dp/B003XDTWN2/ref=sr_1_1?s=home-garden&ie=UTF8&qid=1422886787&sr=1-1&keywords=lasko+100.
Even trying to maintain 75 degrees the unit will eventually stop running and requires the heater to be unplugged for 5 minutes before starting again.
Can you share your chart with the fridge lines enabled?
I do think the power of that heater is a bit on the high side.
Does it have an internal thermostat to prevent overheating?
