Hi I have an issue viewing the ui from my galaxy s9 through the chrome browser. Basically the graph gets overlayed by the block below for 4 seconds then the graph appears for 4 seconds…repeat infinitely. Is this a common problem and is there a fix to stop this happening. See pics.
Coincidentally, work on supporting the UI on mobile started earlier today. This is one of the issues we identified. As it’s really annoying, the fix will likely be in the next release.
To view the graph, you can go to the widget menu, and show the graph maximized.
Perfect thanks bob for the swift reply will await the update and suffer on
I got an old tv and old mouse and keyboard and set them in my garage. If you have space, it’s so convenient to have dedicated equipment to access BrewBlox.
