Hello fellow brewers,
I finished my fridge build a few days ago and wanted to share my results.
I used this fridge (Bomann VS-3171):
https://www.bomann.de/products/de/Bomann-Elektro-Grossgeraete/Vollraumkuehlschraenke/Bomann-Vollraumkuehlschrank-VS-3171-weiss.html
Bomann sells quite inexpensive fridges in Germany, but it should be robust enough for my purposes.
I began by checking out the fridge thermostat:
I am not an expert so I googled a bit and tried around a bit what to do, to go around the thermostat completely. I had to connect all the wires (compressor, light, fridge fan) except ground (yellow/green) for that.
Behind the thermostat enclosure I drilled a hole in the side wall of the fridge (luckily only insulation) for the fridge sensor and beer sensor.
I used the SSRs from the Brewpi shop to switch the fridge compressor and my heater. this is where I mounted the SSR:
I used this reptile cable as a heater:
The cable from the heater is routed through the condensation run-off hole, so apart from the hole in the side wall (for the sensors) I didn’t have to drill.
This is the inside of the finished build (you can see my first brew already fermenting
What you can not see in the picture is the 120mm fan I mounted beneath the wood panel. I just connected the fan to a 12v supply, so it’s basically “always on” (well not really, I can pull the plug out if I want). it has a switch where you can choose from 2 speed settings for the fan.
So far I am really happy with this build. I’d like to switch out the reptile cable for a tube heater sometimes (mainly to save some room, but I’m having a hard time to find a fitting one here in Germany.
Screenshot from my first brew:
