Followed instructions but not sure what or where the dump is saved. Also, still getting random issues of the spark not connecting to the service with spark now connected by usb.
When the UI is working noticed units showing °C even though I have °F selected.
I tried your eeprom on a spark here, and the connection is stable, without a single drop.
I have no clue right now why it would not be stable at your place.
Do you see any difference when the tilt is not online?
@j616s What is the restart interval when the tilt service cannot find a connection?
Is there any mechanism to prevent very frequent restarts of the container?
We see that container restarts shortly take down the host network because it is reconfigured. I think this only happens with ipv6, but perhaps it would be good to introduce a minimal restart interval of 1 minute + some randomness. Or if a container restart is not necessary that would be even better.
I don’t have a tilt running right now. Currently running just to main fridge temp constant, don’t feel like I can trust this to run a brew session as is.
The docker file here showed a tilt service, and he said he used a tilt. So I thought that a tilt service with an offline hardware tilt would cause a continuously restarting docker container, which could mess with connectivity.
The Tilt container doesn’t re-start if it can’t find a Tilt hydrometer. It stays up and waits asynchronously for a callback from the Bluetooth library. Sorry if I misunderstood further up. Thought you were saying you’d spotted the service failing to connect to the data store & restarting.
