SOLVED The problem went away after yet another reboot of the raspi… NOT SOLVED It came back after a couple of hours… :-/
Hello!
I was using Brewblox until last week, when I bottled my last brew. I switched off my spark and fridge, the raspi continued to run. Today I wanted to use the fridge again, but brewblox won’t connect to the spark. I did not change anything in the meantime.
The spark is showing it’s assigned IP address (unchanged) and temperatures and seems to be working nicely. I can ping the spark from the raspi with low latency. It just won’t show up in brewblox.
I updated brewblox to the latest version, rebooted the pi - doesn’t help.
brewblox-ctl discover-spark does not find any devices.
It worked perfectly until I switched the spark off and on again, which is supposed to make things work, normally…
After everything worked fine yesterday after all the intermittent firmware problems, my problem returned yesterday evening, even though I didn’t notice until now. The spark is still showing a correct IP address, a green light, the correct temperatures and setpoints, but BrewBlox shows that the service is running, but can’t get a connection to the Spark.
This might be a problem with my Raspi and my home network because it’s showing some weird behaviour lately (discovery of upnp devices is sometimes a problem), but this hasn’t ever occured with Brewblox / Brewpi before.
Thanks, adding the spark manually works!
I had already set a static IP for the Spark. (For completeness: Restarting brewblox, power cycling the spark or rebooting the Pi did not help.)
Actually, no. This was a bug in RAM allocation. The out of memory handler caused a hangup of the thread manager. This is now fixed.
If you still have reboots with the latest update, can you provide an EEPROM dump so I can make an exact copy of your Spark to find the cause?
Instructions in this thread:
Followed instructions but not sure what or where the dump is saved. Also, still getting random issues of the spark not connecting to the service with spark now connected by usb.
When the UI is working noticed units showing °C even though I have °F selected.
