I just updated to 0.4.4 coming from 0.2.10 which had been working perfectly for 2 (?) years. Long story short, after my last brew I lost all networking on the RPI. So I decided that it was time to upgrade to the latest firmware and while doing so reinstall Raspbian. The upgrade went well with only one hang up while installing on the core which a restart solved. All of my devices were saved and seems to be correct.
After getting it all up and running it does not output anything on the digital pins (checked with a multimeter). So I started trouble shooting with the test mode and found that 1 & 3 work fine but 2 will not stay set to ON. Once pushed it will change to show ON for a fraction of a second and change bach to OFF.
So my question is what to look at to get digital 2 working in test and then how to get output while running a profile a or a constant temperature?
Also I noticed that i can not save changes to any of the devices. I’ve seen this mentioned before but haven’t tried any of the numerous fixes yet.
