Hello again -
Trying to get the brew system up and running, but now having issues with all of the one-wire temperature sensors. Several days ago, I ran the system on water, HLT and Mash Tun, with proper temperature controls through the Spark 4 and had only minor issues with the temperature readings.
I am running my mash pump with a 120 VAC Invertek single phase VFD to control mash flows. After having issues with the one-wire sensors, I checked the Invertek Manual to see if I had all of the grounding properly connected. I also noted that Invertek recommended installing shielded wire to the motor, which I did today. I also ran the pump drive power externally (not with the other wires). Following these changes, I ran the pumps with the Spark 4 energized. The trial was run with none of the 240 VAC heaters energized. When the mash pump is started, I immediately lose all of the one-wire temperature indications. If the pump remains in service, some of the one-wire temps will flash on and off.
I need to figure out how to stabilize my one-wire temperatures. Any help or suggestions you or anyone can provide would be appreciated. Thanks
Ric
