OneWire SSD expansion board - use with own software
Hi Elco,
I have started a project to add temperature control to my greenhouse and to monitor various parameters such as humidity, soil humidity, daylight hours, etc.
I would like to build everything from scratch using the particle photon just to learn and enjoy the DIY aspect of it. I have figured out how to read multiple one-wire sensors and control relays and so getting there…
I would like to incorporate an SSD in the build to control a heating cable that will serve to keep the soil at a constant temp for optimal germination of seeds.
I was wondering if it would be possible to use your SSD expansion board for this purpose - integrating it into my own project and own software. Would you be willing to give me a hand with the coding as to how the address can be searched via the onewire library and then how it can be switch it on and off?
Thanks,
Joost
p.s. I am now 6 or 7 batches in with my brewpi controlled fridge and it is working like a charm, you can consider me a happy customer.
answering my own question: it is based on the well documented DS2413 onewire switch.
post can be disregarded :slight_smile:
yep, If you want to see the source code, look here:
