I got a Spark and other items, including a wall mounted OneWire temp sensor back in February. I finally got my fridge hacked recently, and was doing a dry run - everything looked good, until I unplugged the wall mount sensor at the socket on the fermentor while doing some rearranging in the fridge; when I plugged it back in, that sensor and the chamber sensor were no longer detected by the Spark. If I just have the chamber sensor plugged in, it’s fine, I do get a reading for that one, so it seems to be an issue with the wall mounted sensor.
Is there anything I can do about it? I did manage to get the fridge hacked, but I don’t have a lot of experience with electronics/hardware.
I don’t see many posts here about problems with OneWire sensors, so I suspect this is a pretty rare situation. I did send a message to the customer support email, but haven’t heard anything and thought I would ask here as well.
Hi Elco,
I have a Onewire sensor that from time to time behave like the one Mike has. The sensor does not connect to my Spark one V2 at all, however, the sensor is connected to my Spark 3 also after updating the firmware.
Can you try connecting the sensors to one port at the bottom and one at the top?
Or if you you have an RJ12 cable and extension board, first run a bit of cable and then split off the sensor?
Two sensors plugged in next to eachother can act as a dipole antenna and be extra sensitive to noise of certain frequencies.
I tried connecting one at the top and one at the bottom. Same result - as soon as I plug in the wall mounted one, I no longer get a temp from the chamber sensor, and as soon as I unplug it, the Spark gets the temp from the chamber sensor.
It is a Spark V3, and I did just update to use BrewBlox last weekend, which included updating the Spark firmware.
