Hi
I have a OMV server with docker and portainer. Is it possible /easy to install Brewblox on this? Or is it a bad idea?
It will work just fine. If your OMV server uses HTTP/HTTPS/MQTT ports, you can configure Brewblox to use others. You’ll want to stop the OMV container(s) when installing or updating Brewblox, but this is not a daily hassle.
Performance issues depend on your hardware. I wouldn’t do this on a Pi 2, but it’s workable on a 3, and absolutely no problem on a 4 or most desktop/server computers.
It’s also possible to unify the system, and add the OMV container to the Brewblox docker-compose configuration. This gives you a single stop/start button for everything running on your system, and does not require the containers to interact with each other.
It is not required. If you use Portainer to control OMV, and brewblox-ctl / docker-compose to control Brewblox, then the Brewblox containers will show up in Portainer, but that’s extent of it.
Didn’t understand all off that
So I would install it just as I did on my pi and not from portainer and Docker hub?
Yes.
Short version: it will work. If you get errors about ports already being in use, we can solve it then.
Maybe I’ll try it later and see how it goes
Can I import what I have from my pi Brewblox?
Read it a bit better and not while walking
So port 80, 443 and 1883? OMV uses port 80 as default but that is easily changed. Don’t think the other ports are used but have to check
Why do I have to stop the containers when updating Brewblox?
The update also grabs system updates, which may include docker or kernel updates. It’s probably fine if you don’t stop OMV, but it may cause weird issues on occasion.
Installed brewblox on my OMV. Had to add a new user to get it to work since the existing user didn’t have a home folder. Made a snapshot from the old Brewblox and shut it down. Restored the snapshot on OMV but it wont connect to the spark. what did i miss?
Is the server in the same LAN subnet as the controller?
Is mDNS installed on the server? (Done automatically if it’s a Pi)
You may also need to edit file permissions if the user ID is different, but the log will show that.
Its on the same LAN subnet, 192.168.1.x
Did a search for mDNS and here is the result
auto-apt-proxy/stable 13.3 all
automatic detector of common APT proxy settings
avahi-daemon/stable,now 0.8-5 amd64 [Installeret]
Avahi mDNS/DNS-SD daemon
chezdav/stable 2.5-1 amd64
simple tool to share a directory with WebDAV
designate-mdns/stable 1:11.0.0-2 all
OpenStack DNS as a Service - mdns
forensics-extra/stable 2.29 all
Forensics Environment - extra console components (metapackage)
golang-github-hashicorp-mdns-dev/stable 1.0.3-2 all
simple mDNS client/server library in Golang
libavahi-client-dev/stable 0.8-5 amd64
Development files for the Avahi client library
libavahi-client3/stable,now 0.8-5 amd64 [Installeret,automatisk]
libavahi-core-dev/stable 0.8-5 amd64
Development files for Avahi's embeddable mDNS/DNS-SD library
libavahi-core7/stable,now 0.8-5 amd64 [Installeret,automatisk]
libjdns-dev/stable 2.0.3-1.1 amd64
Simple DNS queries library - development files
libjdns2/stable 2.0.3-1.1 amd64
libjmdns-java/stable 3.5.5-1 all
Java implementation of multi-cast DNS (Apple Rendezvous)
libjmdns-java-doc/stable 3.5.5-1 all
Documentation for Java implementation of multi-cast DNS
libmono-zeroconf-cil-dev/stable 0.9.0-6.1 all
CLI library for multicast DNS service discovery
libmono-zeroconf1.0-cil/stable 0.9.0-6.1 all
libnet-bonjour-perl/stable 0.96-2.1 all
Perl module for DNS service discovery
libnss-mdns/stable,now 0.14.1-2 amd64 [Installeret,automatisk]
NSS module for Multicast DNS name resolution
mate-user-share/stable 1.24.0-2 amd64
User level public file sharing via WebDAV
mate-user-share-common/stable 1.24.0-2 all
User level public file sharing via WebDAV (common files)
mdns-scan/stable 0.5-5+b1 amd64
Scan for mDNS/DNS-SD services published on the local network
mzclient/stable 0.9.0-6.1 all
CLI library for multicast DNS service discovery (commandline tool)
pulseaudio-module-zeroconf/stable 14.2-2 amd64
Zeroconf module for PulseAudio sound server
python3-netdisco/stable 2.8.2-1 all
Library to discover local devices and services (Python 3)
x11vnc/stable 0.9.16-7 amd64
VNC server to allow remote access to an existing X session
avahi-daemon is the relevant one. I assume “Installeret” means “Installed”.
It looks like everything is notionally online, but it does not discover the Spark. Does it show up when you run brewblox-ctl discover-spark?
Yes
INFO Discovering devices…
Type Model Device ID Device host Service
LAN Spark 4 C4DD5766BC14 192.168.1.21
If you check /etc/avahi/avahi-daemon.conf, does it have the setting (without a # in front of it)?
enable-reflector=yes
If it doesn’t, or only has the setting with a #, run brewblox-ctl fix avahi
[reflector]
enable-reflector=no
#reflect-ipv=no
#reflect-filters=_airplay._tcp.local,_raop._tcp.local
I guess something explicitly set it to false. We don’t overwrite explicit “no” settings automatically.
You can edit it with sudo -e /etc/avahi/avahi-daemon.conf. change the no to a yes, and press ctrl-X to save and exit.
When done, run sudo systemctl restart avahi-daemon
Done. Same thing. Also did a reboot
For now you can set a static DHCP lease (ip address) for the spark in the router, and add a --device-host argument in docker-compose.yml
If you like, I can help further debug discovery, but that can get technical quite fast.
First thing I did after setting it up
I use OPNsense and always give my stuff static ip.
If you don’t mind I’d like to debug it further.
