Photon firmware loads successfully but can't read back
Hi all.
I had a load of bits left over at home so have made myself a Brewpi Spark board. I’m using a particle photon rather than a spark core and when I update the firmware, it loads fine but says at the end that it can’t read a version number.
Any ideas?
It is connected directly to Raspberry Pi 2 via USB and the USB connection all looks fine. I’ve also tried multiple leads. Output from update is below.
Detecting DFU devices
Downloading latest firmware…
Latest stable version on GitHub: 0.4.3
downloading https://github.com/BrewPi/firmware/releases/download/0.4.3/brewpi-photon-0.4.3.bin
Firmware downloaded to /home/brewpi/utils/downloads/0.4.3/brewpi-photon-0.4.3.bin
Updated system firmware for the photon found in release 0.4.3
downloading https://github.com/BrewPi/firmware/releases/download/0.4.3/system-part1-0.4.9-photon.bin
downloading https://github.com/BrewPi/firmware/releases/download/0.4.3/system-part2-0.4.9-photon.bin
/home/brewpi/utils/downloads/0.4.3/system-part1-0.4.9-photon.bin and
/home/brewpi/utils/downloads/0.4.3/system-part2-0.4.9-photon.bin
First updating system firmware for the Photon, part 1: /home/brewpi/utils/downloads/0.4.3/system-part1-0.4.9-photon.bin
dfu-util 0.7
Claiming USB DFU Interface…
dfuIDLE, continuing
No valid DFU suffix signature
Downloading to address = 0x08020000, size = 249916
File downloaded successfully
Continuing updating system firmware for the Photon, part 2: /home/brewpi/utils/downloads/0.4.3/system-part2-0.4.9-photon.bin
dfu-util 0.7
dfuIDLE, continuing
Downloading to address = 0x08060000, size = 181428
Now writing BrewPi firmware /home/brewpi/utils/downloads/0.4.3/brewpi-photon-0.4.3.bin
dfu-util 0.7
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 86820
Programming done
Now resetting EEPROM to defaults
Opening serial port
Jul 11 2016 11:12:11 Opening serial port
Warning: Cannot receive version number from controller. Your controller is either not programmed yet or running a very old version of BrewPi. It will be reset to defaults.
pi@raspberrypi:/home/brewpi/utils $
This did actually seem to work at one point and I had the testing screen on my LCD screen where I could turn on the 3 actuators I have and I also had the Testing appear in my brewpi web page. I didn’t have the temp probes plugged in at the time so they weren’t showing. Unfortunately, I accidentally reset the device and it went back to this.
The screen also shows the brewpi logo and just a small message saying to tap to re-calibrate but it doesn’t do anything. I tested and calibrated the screen when I fired it up for the first time so I know that is ok.
Brewpi on the Raspberry pi won’t start the scripts as it says it can’t get the firmware version from the device.
Thanks,
Rich
I seem to have fixed this… I had a couple of bad joints on my Shield which must have been preventing it running properly.
I now need to do a real world test. Both temp sensors are working fine. I am a little worried that I don’t seem to be getting 5v through act 1 2 and 3. I only seem to be able to get 5v through 1 and 3.
Will attach my SSR and fridge tomorrow and test to see if it works. If not, find out why the outputs aren’t working correctly. That’s down to my home made shield though!
