I read through a bunch of threads for this but couldn’t find anything.
I have the balancer/mutex setup and it does work. Both sides get split 50/50 while 100% of both is required but the achieved output is only 33.3%.
I assume this is due to speed of pwm pulse.
Also would lowering pwm pulse to say 1s instead of 4. Would that make boiling more balanced and steady. I feel like the possibility for overshoot in my rims tube with a 30% pump speed during mash would be less likely.
A 4 or 2 second period doesn’t matter for overshoot, which is on a much larger timescale. The PID settings should be tweaked to reduce overshoot.
I wouldn’t go much lower than 2 seconds, because switching between the 2 elements can have a small delay. Just try different values yourself, but give both PWM blocks the same period.
