Just now I am trying to add my second spark to brewblox. I already have a Spark v3 connected and now I am trying to add a Spark V2. While flasing the brewblox-ctl flash went ok but the brewblox-ctl bootloader gives an error. Is this a know issue? I cannot find anything about this in the forum.
pi@raspberrypi:~/brewblox $ brewblox-ctl bootloader
docker-compose down
docker pull brewblox/firmware-flasher:rpi-edge
docker run -it --rm --privileged brewblox/firmware-flasher:rpi-edge flash-bootloader
Running command:
docker-compose down
Running command:
Digest: sha256:d21ad9db2451e2c5492f24e7dadf79696447036bcf7e231dd72b8404f0f4edcb
Running command:
Flashing the bootloader is disabled while we fix a bug.
