Hey guys, I’ve been working on setting up a brewpi for the last week or so and after overcoming a number of hurdles I seem to be stuck at the final one!
(Following these instructions)
I have a Chinese arduino, running on debian wheezy inside VirtualBox
I have updated autoSerial.py with: {‘vid’: 0x1a86, ‘pid’: 0x7523, ‘name’: “Uno Clone”}
I can see my arduino -
ls /dev/ttyUSB0 returns /dev/ttyUSB0
root@debian:/home/pi/brewpi-tools# sudo python /home/brewpi/autoSerial.py
All ports:
/dev/ttyS0 - ttyS0, VID:None, PID:None
/dev/ttyUSB0 - USB2.0-Serial, VID:1a86, PID:7523
Compatible ports:
('/dev/ttyUSB0', 'Uno Clone')
Selected port: ('/dev/ttyUSB0', 'Uno Clone')
When I run python updater.py I get the following:
(Looks like it cannot open the port/cannot detect the arduino.
Any ideas?)
root@debian:/home/pi/brewpi-tools# sudo python updater.py
#### Welcome to the BrewPi Updater! ####
It is not recommended to update during a brew!
If you are actively logging a brew we recommend canceling the the update with ctrl-c.
[Errno 111] Connection refused
Could not connect to socket of BrewPi process, maybe it just started and is not listening yet.
Could not send quit message to BrewPi instance with pid 3619!
Killing it instead!
SIGKILL sent to BrewPi instance with pid 3619!
You are on branch legacy
The latest commit in /home/brewpi is 8b782f0fd5a1d58cfb4f6f08d37ef8f8ef51f28e on Thu, 28 Apr 2016 06:25:47
The latest commit on origin/legacy is 8b782f0fd5a1d58cfb4f6f08d37ef8f8ef51f28e on Thu, 28 Apr 2016 06:25:47
The latest commit in /var/www is 398f1b50c71904f69e836b26299dd178d9d4515a on Tue, 12 Jan 2016 02:16:11
The latest commit on origin/legacy is 398f1b50c71904f69e836b26299dd178d9d4515a on Tue, 12 Jan 2016 02:16:11
Stopping any running instances of BrewPi to check/update controller...
Checking current firmware version...
Oct 03 2017 18:11:35 Opening serial port
Unable to receive version from controller.
Is your controller unresponsive and do you wish to try restoring your firmware? [y/N]:
n
Please make sure your controller is connected properly and try again.
Firmware update done
*** Done updating BrewPi! ***
