Over the last few months I’ve noticed that a WiFi outage (as simple as an access point rebooting from a firmware update) will cause the spark (3) to fail to reconnect and even once it reconnects the spark service requires a manual restart. This didn’t used to happen it I believe I did a Brewblox update a few months back. I updated again but no luck.
Replace all Xs with your specific values. The BREWBLOX_SPARK_DEVICE_ID can be found under your Brewblox Spark service section in the System Info block.
Thanks, I added that but along the way discovered that somehow the Spark is connecting to an old SSID. At least a year ago I split my network into several VLANs. At that time I moved the Spark to my IOT VLAN which required changing the SSID. Apparently its stored the old one as well and has started reconnecting. Very odd. With a reboot, the Spark connects to the desired SSID but I did have to restart the brewblox (did not try just the service) to connect so I’m not sure this fixed my issue.
I did reflash the firmware to the Spark just now, but I believe its been flashed twice sine the issue started before today. I also re-entered the WIFI credentials.
I also have a similar issue with the multiple SSIDs. I haven’t found the fix for that yet and just reboot/reconnect the Spark when it’s connected to the wrong network and roll the dice that it reconnects to the proper network.
On a Spark 3, you can hold the setup button for 10 seconds to clear wifi credentials.
Then brewblox-ctl wifi again to configure wifi. It can remember multiple SSIDs if I remember correctly. Clearing and setting up just one could help.
These changes fixed the Spark side of the issue but the service still isn’t reconnecting automatically all the time. It seems to be when its disconnected for several plus seconds–example, we had a power outage earlier this week so during the time where my generator started and transferred the Spark was down. Wifi and Brewblox were up since all my IT infrastructure is on a UPS.
My spark2 wifi connected brewblox setup has been working fine in a Proxmox LXC for many months. In the last 8 weeks or so i find that the spark controller loses connection with the brewblox service and won’t reconnect again until i power off then power on the spark. After that it works for about 48 hours before the same issue arises and i have to power off/on the controller again.
Whilst the spark is disconnected, it is however online and contactable by http on the ip address and hostname producing the usual line of text e.g. !BREWBLOX,7a42c2d etc etc and the IP address shows on the controller display.
I am updated to latest spark firmware and brewblox version. I have the controller ID and host IP in my docker-compose.yml. It doesn’t help to reboot brewblox.
Does this sound like your issue matt or is it different?
Sounds similar. It happened last week and I did have to power cycle the spark. It’s in a cabinet so I didn’t see the screen but will check next time it happens. I’ll check if it’s on the network too.
Some more observations as the same thing has happened again a few times.
To confirm, when the spark-brewblox connection breaks, the spark is still contactable on http by ip address and hostname. However, the spark actually stops controlling the fridge so for instance the fridge just goes up to ambient temperature.
This remains the same until I power cycle the spark which resolves the issue instantly so it connects to brewblox and starts up control of the fridges etc.
The time frame for how long it takes after a spark reboot to lose connection again is variable. A couple of times it was about 48 hours but other times it has been longer. On 2 occasions it appears to have happened after the wifi access point goes down for a period of time - most recently it was down for about an hour and when it went back up it was in that non-connected state (with fridge control not working) despite the fact it was accessible on http by ip address.
This issue has been present about 2 months now. Is it possible the spark firmware (or hardware) could have got corrupted? is there a way to force re-flash the spark if that is worth trying?
