Is it possible to remove dates from the profiles so that they can be reused without editing them?
Profiles are date based, because a reboot would otherwise reset the start time. You can open the profile and click ‘start now’. Then your profile will shift to the current date. Is that not suitable for you or did you not know it was possible?
Did not know, will try.
Would there be any issue setting up output two as boil controller and use a beer/fridge constant? I followed your lead on the herms setup, but it might make sense to shift fridge/chamber to get boil control?
