Hi, i would like to suggest making it possible to have an option in the settings menu where i can enable/disable password protection. As you may figure out, i am not good at programming. I have seen the post for doing it at homebrewtalk, but i get stuck on number 3
What is step #3? If you could post where you are getting stuck we may be able to point you in the right direction.
Cheers,
-Stephen
Yes, sorry. Itās this one.
I am so bad at this programming stuff
Ok so this is a bit more of an advanced topic, but these are pretty old instructions and may be out of date. The Apache webserver has gone through a bit of changes and depending on how it was installed these instruction could be frustrating.
I would suggest you break this down into parts and tackle them bit by bit and make sure you arenāt just reading the directions but taking the time to learn what each is asking you for and what that is/means.
Youāve got SSH to work and you can log into your Raspberry Pi youāve found the default file but you canāt find anything that mentions /var/www is this correct? If that is the case this is why I said be careful with old instructions especially if you are not familiar with *NIX based OSs and their applications. Apache if installed by the *NIX package manager may have changed the default HTML directory, so if you are reading old stale instructions you will end up beating your head on the wall looking for something that doesnāt exist. At this point is where you ask the question of WTH is that anyway and the answer is the directory options for the root directory for the HTML content. The default file is a configuration file that tells the Apache server where things are, what should be enabled, and how to run. In this file you can tweak many things and what you are being asked to do is enable a bit that allows you to use simple HTACCESS file protection. What you need to find in this file to help point you in the right direction is where the root directory points so in that file look for something like this:
DocumentRoot /var/www
That will tell you what you should be looking for in the:
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
allow from all
</Directory>
But really I canāt stress enough to not just do something, but take the time to read and understand what it is you are doing. This will make life with the BrewPi much easier in the long run. If you get stuck with something and Google canāt turn up an answer we are always here to help, we all had to start somewhere so believe me we understand.
Cheers,
-Stephen
Thanksās Stephen, thatās why i am so careful. Iām so afraid to do something thatās not reversible. Iāl do my best to learn this, since it looks like this is the only way to go, at this time, to get BrewPi protected.
Cheers
Kai
And Iām sure youāve seen the updated version of that HBT post but here it is. It worked better for me.
I just did this a few days ago. Let me know if you get hung up on any of that stuff.
If you follow these directions, you will end up with two remotely accessible web user interfaces. One that requires a password and has all the controls available to you and another page that is not password protected but does not have any of the control buttons available.
Here is my non-password page. Its just logging living room temp right now but you can see what it looks like without the settings options. (I changed my ipās to address via no-ip, but thatās for later and not in that post you referenced).
FYI the link doesnāt work for me. The connection times out.
@Dan you talking about my BrewPi link or the homebrew talk link? They both work for me clicking on them.
the brewpi link sorry
The server at 72.182.26.140 is taking too long to respond.
I can access the BrewPi link, showing āFermenting: RastaManās Dubbel WLP500/530 Blendā. Sounds tasty!
Right on @DanCook! Glad itās working. The beer started at 64° and slowly worked its way up to 71.5° over last 10 days (controlled with a ohmbrew fermostat). Just plugged in the BrewPi setup for the first time tonight to test it just holding that temp till I keg it. Iāll use the BrewPi for real next week.
Has anyone had success adding password to the web interface with Portainer? I cannot find apache or the directory /etc/apache2/sites-available.
I believe the Portainer Brewpi is using Nginx and not Apache. https://nginx.org/en/
26507 brewpi 20 0 13608 10844 5208 R 67.9 2.9 0:02.05 python
26506 root 20 0 7232 2912 2616 S 1.7 0.8 0:00.05 sudo
39 www-data 20 0 15712 4240 2948 S 0.3 1.1 5:29.44 nginx
26505 root 20 0 5124 2328 2036 R 0.3 0.6 0:00.09 top
1 root 20 0 1816 1080 1012 S 0.0 0.3 1:28.02 watcher.sh
35 root 20 0 15196 2608 1792 S 0.0 0.7 0:00.01 nginx
36 www-data 20 0 15672 4240 2948 S 0.0 1.1 1:00.43 nginx
37 www-data 20 0 15364 3304 2324 S 0.0 0.9 6:27.89 nginx
38 www-data 20 0 15364 3684 2704 S 0.0 1.0 6:27.30 nginx
58 root 20 0 89116 6436 4272 S 0.0 1.7 5:08.61 php5-fpm
60 www-data 20 0 89116 9896 7556 S 0.0 2.6 0:00.51 php5-fpm
123 www-data 20 0 89116 9384 7044 S 0.0 2.5 0:00.43 php5-fpm
163 root 20 0 5192 3040 2704 S 0.0 0.8 0:00.19 bash
189 www-data 20 0 89116 9152 6924 S 0.0 2.4 0:00.10 php5-fpm
26427 root 20 0 5196 3064 2724 S 0.0 0.8 0:00.41 bash```
Yup, did not check that. Thanks!
I managed to set a password. Hereās a simple tutorial if anyone needs it: https://www.howtoforge.com/tutorial/basic-http-authentication-with-nginx/
I also forwarded a port from my router to the Pi. How safe is that? (having user+password)
I have added password protection to the latest version of the docker container.
The latest version of the container exposes two ports:
port 80 for use on your internal network, without password.
port 81 for forwarding on your router, with password.
The default user is brewer and password brewpi.
You can change that by running this command in the container (replace brewer and brewpi with your desired user/pass):
htpasswd -bc /data/settings/brewpi.htpasswd brewer brewpi
The nginx configuration for this can be found here:
