"Restore defaults" causes script error
Hey guys,
I’m hoping you can help me out. Whenever I use the restore defaults option in the advanced setting tab my web interface loses the ability to load the script. The error log says that it has encountered a stop script. If I run sudo python updater.py then everything is fixed. If I push restore defaults then the same thing happens. One clue may be that my web interface is for some reason located inside /var/www/html as opposed to the default /var/www. Im not sure how that happened in the first place.
Thanks,
Matt
