Hello all,
I am running Brewblox on a Raspberry Pi 3 Model B Rev 1.2. Recently I have had issues with is stopping responding. The web interface dies and I cannot connect on ssh. This happens more frequently during updates using apt, or updating with brewblox-ctl - from this I assume it is possibly the SD Card as this seems to be a common cause.
From StackExchange, https://raspberrypi.stackexchange.com/questions/49862/sd-card-related-random-freezes , someone commented that disabling swap helps, would that negatively impact Brewblox at all?
Another suggestion was: āMore practically you should try implementing the watchdog timer (included on the SOC) to detect failure and perform a graceful restartā not sure if that is something which can be enabled in Brewblox.
Any other ideas of how to troubleshoot what might be causing this? I can easily buy a new card, but would like to confirm that this will fix it, I wish the RPi had SATA ports, I have a couple spare SSDs
The /var/log/syslog leading up to where it appeared to be unavailable (and when I then restart it) are below:
Jun 22 20:59:02 fridgepi dhcpcd[511]: veth3a94e19: using IPv4LL address 169.254.193.216
Jun 22 20:59:02 fridgepi dhcpcd[511]: veth3a94e19: adding route to 169.254.0.0/16
Jun 22 20:59:02 fridgepi avahi-daemon[351]: Joining mDNS multicast group on interface veth3a94e19.IPv4 with address 169.254.193.216.
Jun 22 20:59:02 fridgepi avahi-daemon[351]: New relevant interface veth3a94e19.IPv4 for mDNS.
Jun 22 20:59:02 fridgepi avahi-daemon[351]: Registering new address record for 169.254.193.216 on veth3a94e19.IPv4.
Jun 22 20:59:04 fridgepi dhcpcd[511]: veth3a94e19: no IPv6 Routers available
Jun 22 21:00:55 fridgepi containerd[519]: time=ā2020-06-22T21:00:55.031207044+01:00ā level=info msg=āshim reapedā id=16f0cbf366fb04f6cc7de913a31c82857bff194c69ad1ece634621cb8ca45b52
Jun 22 21:00:55 fridgepi dockerd[521]: time=ā2020-06-22T21:00:55.042214846+01:00ā level=info msg=āignoring eventā module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Jun 22 21:00:55 fridgepi dhcpcd[511]: veth3a94e19: carrier lost
Jun 22 21:00:55 fridgepi dhcpcd[511]: veth3a94e19: deleting address fe80::74f9:47e:790d:ec6f
Jun 22 21:00:55 fridgepi avahi-daemon[351]: Withdrawing address record for fe80::74f9:47e:790d:ec6f on veth3a94e19.
Jun 22 21:00:55 fridgepi avahi-daemon[351]: Leaving mDNS multicast group on interface veth3a94e19.IPv6 with address fe80::74f9:47e:790d:ec6f.
Jun 22 21:00:55 fridgepi avahi-daemon[351]: Joining mDNS multicast group on interface veth3a94e19.IPv6 with address fe80::c882:2ff:fec3:5b7b.
Jun 22 21:00:55 fridgepi avahi-daemon[351]: Interface veth3a94e19.IPv6 no longer relevant for mDNS.
Jun 22 21:00:55 fridgepi avahi-daemon[351]: Leaving mDNS multicast group on interface veth3a94e19.IPv6 with address fe80::c882:2ff:fec3:5b7b.
Jun 22 21:00:55 fridgepi avahi-daemon[351]: Interface veth3a94e19.IPv4 no longer relevant for mDNS.
Jun 22 21:00:55 fridgepi avahi-daemon[351]: Leaving mDNS multicast group on interface veth3a94e19.IPv4 with address 169.254.193.216.
Jun 22 21:00:55 fridgepi avahi-daemon[351]: Withdrawing address record for fe80::c882:2ff:fec3:5b7b on veth3a94e19.
Jun 22 21:00:55 fridgepi avahi-daemon[351]: Withdrawing address record for 169.254.193.216 on veth3a94e19.
Jun 22 21:00:55 fridgepi dhcpcd[511]: veth3a94e19: deleting route to 169.254.0.0/16
Jun 22 21:00:55 fridgepi systemd[1]: run-docker-netns-1b0bbb8d6ec1.mount: Succeeded.
Jun 22 21:00:55 fridgepi dhcpcd[511]: veth3a94e19: removing interface
Jun 22 21:00:55 fridgepi systemd[1]: var-lib-docker-containers-16f0cbf366fb04f6cc7de913a31c82857bff194c69ad1ece634621cb8ca45b52-mounts-shm.mount: Succeeded.
Jun 22 21:00:55 fridgepi systemd[1]: var-lib-docker-overlay2-91358d1b953db5560cd5643f4e4ff491b13c47bc20de1a2384a30b8b3ae65c07-merged.mount: Succeeded.
Jun 22 20:17:05 fridgepi fake-hwclock[112]: Mon 22 Jun 19:17:01 UTC 2020
Jun 22 20:17:05 fridgepi systemd-fsck[138]: e2fsck 1.44.5 (15-Dec-2018)
Jun 22 20:17:05 fridgepi systemd[1]: Started udev Coldplug all Devices.
Jun 22 20:17:05 fridgepi systemd[1]: Starting Helper to synchronize boot up for ifupdownā¦
Jun 22 20:17:05 fridgepi systemd[1]: Started Helper to synchronize boot up for ifupdown.
Jun 22 20:17:05 fridgepi systemd-fsck[138]: root: clean, 283538/1826816 files, 1999591/7303296 blocks
Jun 22 20:17:05 fridgepi systemd[1]: Started File System Check on Root Device.
Jun 22 20:17:05 fridgepi systemd[1]: Starting Remount Root and Kernel File Systemsā¦
Jun 22 20:17:05 fridgepi systemd[1]: Started Remount Root and Kernel File Systems.
Jun 22 20:17:05 fridgepi systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jun 22 20:17:05 fridgepi systemd[1]: Starting Flush Journal to Persistent Storageā¦
Jun 22 20:17:05 fridgepi systemd[1]: Starting Load/Save Random Seedā¦
Jun 22 20:17:05 fridgepi systemd[1]: Starting Create System Usersā¦
Jun 22 20:17:05 fridgepi systemd[1]: Started Set the console keyboard layout.
Jun 22 20:17:05 fridgepi systemd[1]: Started Load/Save Random Seed.
Jun 22 20:17:05 fridgepi systemd[1]: Started Flush Journal to Persistent Storage.
Jun 22 20:17:05 fridgepi systemd[1]: Started Create System Users.
Jun 22 20:17:05 fridgepi systemd[1]: Starting Create Static Device Nodes in /devā¦
Jun 22 20:17:05 fridgepi systemd[1]: Started Create Static Device Nodes in /dev.
Jun 22 20:17:05 fridgepi systemd[1]: Reached target Local File Systems (Pre).
Jun 22 20:17:05 fridgepi systemd[1]: Starting udev Kernel Device Managerā¦
Jun 22 20:17:05 fridgepi systemd[1]: Started udev Kernel Device Manager.
Jun 22 20:17:05 fridgepi systemd[1]: Found device /dev/serial1.
Jun 22 20:17:05 fridgepi systemd-udevd[152]: Using default interface naming scheme āv240ā.
Jun 22 20:17:05 fridgepi systemd[1]: Found device /dev/mmcblk0p6.
Jun 22 20:17:05 fridgepi systemd-udevd[155]: Using default interface naming scheme āv240ā.
Jun 22 20:17:05 fridgepi systemd-udevd[152]: Process ā/usr/sbin/alsactl -E HOME=/run/alsa restore 0ā failed with exit code 99.
Jun 22 20:17:05 fridgepi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jun 22 20:17:05 fridgepi systemd[1]: Condition check resulted in FUSE Control File System being skipped.
Jun 22 20:17:05 fridgepi systemd[1]: Condition check resulted in Huge Pages File System being skipped.
Jun 22 20:17:05 fridgepi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Jun 22 20:17:05 fridgepi systemd[1]: Starting File System Check on /dev/mmcblk0p6ā¦
Jun 22 20:17:05 fridgepi systemd[1]: Starting Load/Save RF Kill Switch Statusā¦
Jun 22 20:17:05 fridgepi systemd[1]: Started Load/Save RF Kill Switch Status.
Jun 22 20:17:05 fridgepi systemd-fsck[273]: fsck.fat 4.1 (2017-01-24)
Jun 22 20:17:05 fridgepi systemd-fsck[273]: 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt.
Jun 22 20:17:05 fridgepi systemd-fsck[273]: Automatically removing dirty bit.
Jun 22 20:17:05 fridgepi systemd-fsck[273]: Performing changes.
Jun 22 20:17:05 fridgepi systemd-fsck[273]: /dev/mmcblk0p6: 236 files, 104463/516188 clusters
Jun 22 20:17:05 fridgepi systemd[1]: Started File System Check on /dev/mmcblk0p6.
Jun 22 20:17:05 fridgepi systemd[1]: Mounting /bootā¦
Jun 22 20:17:05 fridgepi systemd[1]: Mounted /boot.
Jun 22 20:17:05 fridgepi systemd[1]: Reached target Local File Systems.
Jun 22 20:17:05 fridgepi systemd[1]: Starting Raise network interfacesā¦
Not sure if that helps.
Thanks,
Jerry
